Motor question....
Discussion in 'The Garage' started by Calclips, Aug 6, 2002.
  1. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I'm looking at buying this K20 from a local wheeler. I know this thing has seen alot of offroad time in it's day, it's got a t350 tranny and a 205 t-case swapped into it. The motor looks to be fairly new, it has a nice fresh coat of paint on it and isn't a leaky SOB. The guy I may buy it from pulled the old intake and carb off of it and swapped it out, while he was in there he said that the oil galleys were clean as a whistle, and when he rolled over the motor all of the lifters came up good and the cam didn't appear to have any flat spots in it. Does this mean that the motor is most likely going to be a solid motor, or is that not enough information to base an estimation on?
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    If you are concerned about the motor, just do a compression test. All cylinders should be within 10% of one another.
    Mike
  3. Calclips
    Apr 4, 2001
    1,005
    What should the compression be arround? The motor is pretty much stock.
  4. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    If it is a stock 350 and IIRC it should be around 125 to 150 PSI. Anyone?
    Mike
  5. Calclips
    Apr 4, 2001
    1,005
    how do you work a compression tester?
  6. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    You stick the rubber end in each spark plug hole and turn the engine over a couple of times unless you have the expensive threaded one the you screw it in the spark plug holeand turn the motor over a couple of times.
  7. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    The threaded one is most accurate. Hold the throttle wide open and spin it over 4 or 5 times. 125-150 is good compression...
    If you find a cylinder that reads low remove the tester from that hole and squirt in a tablespoon or so of oil. Now test it again. If the compression is higher with the oil the rings are worn, if there is no change the compression loss is valve related.
    Rene
  8. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    That is a cool trick with the oil never though about doing that one more reason CK5 is great.
  9. BIG STEVE
    BIG STEVE Registered Member
    Jul 23, 2002
    66
    thornton colorado
    dont forget to pull all the plugs before you start
    90 jimmy 350tbi sm465 241 14rear 10 lock right front
    web page
  10. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    Why would you need to pull all the plugs? Shouldn't you just pull the coil wire to prevent it from starting?
  11. lizard
    lizard 1/2 ton status
    May 11, 2002
    114
    Tallahassee, Florida
    To allow the engine to spin freely. But be warned! Before you pull all the plugs be sure to clean the engine and around the plug holes (compressed air works good) or you can suck in dirt, sand, etc.
    The i d uh behind a compression test is to check the condition of the engine without doing damage /forums/images/icons/wink.gif
