Motor swap complete... the first starting attempt
Discussion in 'The Garage' started by 78Suburban, Jan 6, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I didn't get to turn the motor over for more than about 3 or 4 seconds, because my battery was low. I've got it charging now, and will attempt it again tomorrow. For the few seconds it was turning over, it was making some kinda odd noise, or at least something I don't think I ever really heard before. It was coming from the flexplate/starter area I think. I wish I knew how to describe it, but I don't.. it was like a metalic straning, grunting noise, I guess you could call it.. I really wish I had somebody around here that knew what they were doing to listen to it. I'm gonna try it again tomrrow... in the mean time, does anyone have any idea what's causing this noise? perhaps I did something wrong when I put the starter on??
    thanks,
    James
  2. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Take your inspection cover off and see if anything is rubbing. Make sure the starter is lined up correctly. Make sure your flexplate/converter bolts are in right and tight.
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    Did you seat your converter all the way?
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Try it with the new/recharged battery before you start pulling it apart. If you get the same noise straight away then stop and investigate.
    Turning a motor over with a low battery puts a strain on all parts involved. A rebuilt motor is tough on the starter system anyway, then making it turn it over slow is even harder. Get it to spin up fast with the recharged battery and see how it sounds.
    Good luck.
  5. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Wait till you try it with a strong battery. Chevy's can sometimes need shims to get the starter in the righ spot. Heres something unrelated... I'm just gonna go ahead n ask this... did you prime the oil pump to make sure everything is lubed?
  6. PeteH
    PeteH 1/2 ton status
    Mar 26, 2003
    498
    San Jose
    i think i had the same weird noise. it would catch a little then free wheel.. flex plate was fine and the gear in the starter was fine.. i took off the starter and part of the cast houseing was cracked off. so the starter was moving everytime i cranked and back in place when not cranking. replaced the starter and it was perfect.
  7. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    If I'm lucky it was just the low battery causing the funny noise. I am really, really hoping that I didn't bend/warp my flexplate. The more I think about it, the more I realize this could be a posiblity, because when I was installing the engine, it wanted to go down at a funny angle and make the flexplate hit the bellhousing/ torque converter. Good grief I don't wanna have to change that thing out.. Has anybody here ever been goofy enough to accidently do that, or stupid enough to actually admit it :doah: ? Yeah I suck.. If Mr. Bean tried to work on a truck, he would be like me. Tomorrow will tell the whole story, I guess I can take the dust cover off and watch as the engine turns over.. I'm thinking this very well maybe be the problem... Yeah, my day is ruined.
    thanks,
    James
  8. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    When I first got my K5 from the previous owner, it would make an awful racket coming from the flywheel area when I cranked it over. Turns out the starter wasnt shimmed correctly. Use a 1/8" drill bit as a guage and put it between the flexplate gear and starter shaft. Yo need that 1/8" no more, no less. If it is too far, shim the outboard side, if it is too close, shim the inboard side.
  9. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    thank you muddytazz!!
    On an instant messenger conversation, Muddytazz has brought it to my attention that flexplates are made of steel that will break before it bends. This makes me feel ALOT better, and puts my mind at some ease.. He also said that a low battery would cause the starter to make the noise I described. So now I have an optimistic outlook for tomorrow, and can actually get to sleep tonight :bow: thank you!
    thanks,
    James
