Motor swap survey
Discussion in 'The Garage' started by 78Suburban, Oct 31, 2005.
What should I do?
  1. Remove AC and Heater. Put air intake in the cab
    8.3%
  2. Remove AC, make heater work somehow
    60.0%
  3. Replace both my AC and Heater
    31.7%
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I am going to be doing a motor swap over Christmas break, hopefully. My truck has the old school R-12 AC, and it has a heater. I don't know much at all about either one of these systems. So what should I do when I do my motor swap?
    This truck will be used for trail riding and mud bogging. all seasons.
  2. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    In Georgia you probably don't need a heater as bad as in Ohio :crazy: but it's always good. If you just want to take the drag off the motor, all you have to do is remove the A/C compressor and get a smaller belt ('78 Suburban right?). Serpentine belt will be more difficult. Either way, the heater should work even if you remove the A/C compressor, condensor (A/C's radiator like thing), and plumbing for A/C. Of course you can always go get just a heater setup from a junkyard.
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    dont need ac :D thats what windows are for, also remove the op, but u got a burban. heat is alot more important, i can stand sitting in traffic when its 95* with no ac, but shivering to death when its 20* and no heat is a b****, i had to do it all last winter :mad:
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I would guess you'll want that A/C in the summer.
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    It shouldn't be that hard to swap the AC...and you live in Georgia...just do it.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If the a/c system still works , use it . Does it blow cold ? If it does , leave it hooked up to the lines , just unbolt it from the motor and move it to the side , and try not to hurt it removing the motor :D
  7. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    personally, I like a/c a lot, but i dont think it is necessary, keep your heater as it is nice int the winter and it can act as a second radiator if your real radiator get clogged with mud.
    I would keep a/c if its not too dig a deal.
  8. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    3,651
    No VA.
    Problem is, while offroading, you're not going fast enough to make it worth your while. A couple months ago, while riding with some buddies, the heat inside the cab (from the motor, etc) got very hot, but I didn't really realize it. 'Sure, well then, get outta the cab, a$$hole".... Not when I'm stuck, wedged against a tree, and can't get out of the drivers seat until I get freed. "Drink more water".... I hydrated more then enough the days leading up to the ride. It wasn't until I damn near passed out and fell out of the truck onto the dirt, had to have my friends Pop drive my truck off the trail, and have someone I didn't know on a quad take me back to the tow rigs for a trip to the hospital. I don't care how much horsepower it robs, I will have A/C in my trial rigs.
  9. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    Yes it blows cold. I guess I will try to reuse it.. What if the R-12 escapes, will I melt like the wicked witch? I'm not familiar at all with AC systems.. :bow:
  10. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Na, you'll be fine. Its real bad for the environment. Just get out of the way if it sprays out.
  11. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    I'ts not much more work to tie the ac off to the side if swapping similar packages (ie sbc to sbc) If it works i would only consider taking it off if you were going to a bbc and didn't have the right brackets or something like that.
    As for heat, i am not familiar with your home area, but defrosters are always important in early morning dewey conditions and rain.
    If your motivation is to put the intake in the cab, think about the cowl area.. You can move a 70s style radiator support end to the U shaped area above your ac on the firewall and hook the stock intake hose to it. That's what I did and it worked well for me, just have to cut a hole.
  12. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    Very, good points, thanks for the advise... I wasn't even thinking about fogging up the windows :doah: ... I'll definitely try to keep the heater and AC.. Do you have any pics of your air intake setup?
    thanks,
    James :bow:
  13. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    the refrigerant wont hurt you unless theres an open flame around, thats when it becomes deadly. if a little leak out then it shouldnt be a big deal, but it shouldnt anyways, you should have to hit the schrader valve to do taht.
  14. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    it isnt as bad to let R12 out into the environment as it is producing 134a. dunno why they switched. :screwy:
    a little word of advice if you're going to leave the AC intact when pulling the motor... put a piece of plywood, or fairly thick metal between the condenser and the engine. this will avoid damage to the condenser. personally i have a piece of 1/8" steel that i keep around specifically for this purpose.
  15. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    This is gonna get a really good laugh......... but........here's my noob question......................................................................................................... What is a Condensor? where is it and what does it look like :bow: :laugh: :bow:
  16. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Do it right while you are in there (install heat and AC)and you won't regret it down the road :wink1:
  17. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    the AC radiator.
  18. RustyParts
    RustyParts 1/2 ton status
    May 26, 2005
    235
    Wyman, Kentucky
    A/C systems went to R134 supposedly because the R12 was destroying the ozone layer above the earth.
    Your present A/C system can be converted to R134, most auto stores carry kits to do this.
  19. dubbyx
    dubbyx Registered Member
    Nov 14, 2005
    49
    Lubbock, TX
    convert it now...
    it seems to me it'd be more hassle to try and save everything as it is... even at the worst, you're looking at about $250 in parts to put a whole new a/c system in using most of the same stuff you've got now.
    if you go ahead and convert it over, you'll know how to fix it when it breaks down the line, or if you have to pull the engine out for something later.
    to be on the completely safe side, go have the r-12 drained at a service station... no damage to the "ozone" and you won't have to risk breathing the stuff... the 134a's bad enough
    what kind of swap are you gonna do anyway? just sbc-sbc? or going BB? I'm getting the parts together to put that Olds 455 in my '84 burb.... having a hard time sleeping I'm so darned excited about it.
  20. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    it's not too scary if you spring a leak, just make sure you get outta the way. that stuff can burn you if you get too much on your skin and leave it there. it feels similar on the skin as dry ice. :) but i think you should try and keep both systems - neither one is too difficult to work with. good luck.
