motor temps
Discussion in 'The Garage' started by bigbadchev84, Jul 4, 2006.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    as posted in another post i was out mudding today, i have a mildly built 350 with a 4 core radiator, fan shroud, and 5 blade clutch style fan, not sure of the t-stat, i usually run 210 around town, well thats what the stock gauge says and i was almost pegging the motor out today i pulled the grille out and threw buckets of water through the radiator is there anything else i can do to avoid this?
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    was the motor actually that hot, or is the gauge/sending unit just screwed? If the sending wire comes off the sender, and the connector touches something metal (head, manifold, etc), it will peg the gauge out
  3. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    when was the last time you flushed the cooling system....and changed the T-stat?
  4. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    4core is new and so is the fluid, fluid was fine, the temp cam back down to 210 after throwing buckets of water at it, it did feel really hot, motor acted fine though, the motor came out of an 80 el-camino and that is what the sender is from also
  5. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Might tap in with a mechanical gauge just to check the actual temperature. The El Camino sending unit might not match your current gauge.
  6. smalltowncowboy
    smalltowncowboy 1/2 ton status
    Jan 16, 2006
    503
    hermiston oregon
    my motor is built a little bit and i had to run dual electric fans to keep mine cool. since its summer you might pull your t-stat all together. 100 degree weather doesnt help keep it cool
  7. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    yeah i might throw a pusher on there, pulling the stat can make it worse from what i hear cause it wont stay in the radiator long enough to cool
  8. smalltowncowboy
    Jan 16, 2006
    503
    hermiston oregon
    ive pulled the stat on alot of my rigs and theyve all ran cooler, never hotter.
  9. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Are you running an auto trans? What's your tire size & gearing? Were you in 4Hi or 4Lo? These things make a difference.
    For a quick improvement, put some Redline Water Wetter in the radiator; about 3oz per gallon of coolant IIRC.
    Personally, I disagree with pulling the thermostat. All three times I saw it done to a vehicle that was overheating, the problem got worse rather than better.
  10. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    How much mud came out of your radiator when you were pouring water through it?
  11. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    This is one of the oldest urban myths. If it isn't in the radiator long enough to cool, what makes you think that it will be in the motor long enough to get hot? More flow is always better.
