Motor
Discussion in 'The Garage' started by mudjunkie 82, Feb 1, 2004.
  1. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    What motor does everyone run, and any future plans for it?
  2. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    427 Tall Deck. Plans either just rebuild it or maybe bore stroke to some thing big. /forums/images/graemlins/thinking.gif
  3. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    350 now, plan to build BBC!
    Bill
  4. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I run a 305 right as of now but plans are for either a 350-400 or a BB. These plans are of course way down the road.
  5. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    TBI 454 right now. I am pulling it this spring to add Multi-Port and Edelbrock Aluminum heads and a roller cam. If I have any $$ left over, I will be adding and Eagle ESP forged 4.25" crank. Luckily I already have a set of Eagle ESP H-beam 6.385" rods hanging around and a set of Weisco 10:1 pistons /forums/images/graemlins/peace.gif But the crak my have to wait since the heads and MPFI are gonna set me back a bit...
    Chris
  6. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    TBI 454 now. if/when it goes, will most likely go crate 502. Put my roller cam set up in it.
  7. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    I have an OEM type starter motor. Although to move the truck I will use a 388 Small block chevy.
  8. RustBuket
    Feb 21, 2003
    1,618
    Ah yes the whole motor=electric and engine= combustion type debate /forums/images/graemlins/thumb.gif
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    400 small block. Hope to have a 454 in the near future. /forums/images/graemlins/deal.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/waytogo.gif
  10. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    388 stroker. /forums/images/graemlins/woot.gif
    The only plans I have are to possibly change the induction. I'll go Q-jet or TPI or Edelbrock MPFI if I win the lottery or something. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/histerical.gif
  11. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    350 with Q-jet for now. Might go fuel injected later.
  12. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    stock 350 with holley contender intake and holley 4 barrel carb, cfm unknown, stock manifolds and true dual 2" with cherry bomb turbo 2 mufflers hanging on..
    future plans include aluminum heads, qjet, edelbrock air gap intake, long tubes and full 2.5" exhaust..
    farther future plans include a 385" stroker from the 4 bolt 010 block in the garage..
  13. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    TBI 350 with around 160,000 miles on the clock. It's starting to blow smoke on startup so it's just breaking in! /forums/images/graemlins/grin.gif I'll either rebuild it with a mild cam and some head porting or just go to a 454 with TBI. depends on how much ching I have in the bank at the time /forums/images/graemlins/whistling.gif
  14. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I am one of those wierdo in-line six guys /forums/images/graemlins/eek.gif /forums/images/graemlins/1zhelp.gif- I run a 292 /forums/images/graemlins/waytogo.gif w/ T.B.I. w/ Offy intake - Crane wiggle stick/CompCams timing gears - LPG pistons - and the usual balanced rotating assy.
    Tom /forums/images/graemlins/thumb.gif
    My future plans for it is to have it run for many years TROUBLE FREE ! atleast that's what I am hoping for .....
  15. pineyjon
    pineyjon Registered Member
    Aug 23, 2003
    80
    south jersey
    goodwrench 350 w\edelbrock performer intake, carb, and cam. future plans for a caddy 500 swap
  16. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    Goodwrench 350 4bolt main, warranty voided right off the bat. Installed crane true double roller timing chain with thrust bearing and cam button. Comp cams self aligning magnum roller rockers and push rods. Weiand dual plane aluminum manifold with egr. Edelbrock tubular exhuast system with high flow cat, and flowmasters. Weber quadrajet 785 cfm. Melling high volume oil pump. MSD Pro billet HEI. /forums/images/graemlins/grin.gif
  17. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Currently running a built 406 small block with 9,000 miles on it so far. /forums/images/graemlins/peace.gif It's got a high volume oil pump, comp 268H cam, 9.2:1 compression, edel. performer intake, retuned edel. performer Q-jet, recurved perf. HEI,K&N filter, hooker competition full length headers, dual 40 series flowmasters.
    Future plans are AFR 195cc aluminum heads, 50HP shot of squeeze, and maybe edel. multi port fuel injection. That should put me around 475HP or so and BBC spankin' torque. /forums/images/graemlins/woot.gif /forums/images/graemlins/waytogo.gif
  18. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    Im running a stock TBI 305 now. Runs awesome for all offroad situations(mud excluded). But its my daily driver and she doesnt have enough umph /forums/images/graemlins/frown.gif Plan is to build a stock tbi350 or a mild tbi383. /forums/images/graemlins/grin.gif Probably the 383 because those ricers piss me off sometimes /forums/images/graemlins/thumb.gif
  19. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    A GM zz4 350... (LT-1)
    I've beat that motor...and it still wants more!!! /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
  20. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    wtf is a motor /forums/images/graemlins/dunno.gif
