Motorcycle tech help - 78' KZ400 help!
Discussion in 'Other Rides' started by BigBurban350, Jun 29, 2003.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Motorcycle tech help - 78\' KZ400 help!
    I cant find a motorcycle forum. Maybe somebody has a Kawasaki bike similar to mine. Its a 78' KZ400, and it has a charging problem. The battery slowly dies as the engine runs. I tested the rectifier and it seems to work. I also tested the output AC voltage from the stator and it was putting out about 60 volts or so. Am I forgetting to check something.
    Everything else is golden on this bike, I really want to get this bike going so any help would be grateful.
  2. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Re: Motorcycle tech help - 78\' KZ400 help!
    have you checked the power at the battery cables with the bike running? Also, have you had the specific gravity in the battery checked. Motorcycle batteies are notorious for "temporary" charges.
    John
  3. BigBurban350
    Jun 9, 2002
    711
    Michigan
    Well, I figured out the problem when I checked the amp draw which was excessivly high. So I started disconnecting lights until I found the shady headlight that somebody jb welded the incorrect light bulb into it /forums/images/graemlins/tongue.gif.
  4. BigBurban350
    Jun 9, 2002
    711
    Michigan
    John
    Hey, the battery was bad also /forums/images/graemlins/tongue.gif, my bro happened to have the same battery brand new in box. So I filled her up with some fresh electrolyte, and now it stays charged. WOOHOO!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
