mounted my dirt grips pics
Discussion in 'The Garage' started by rdn2blazer, Nov 23, 2005.
  1. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    Started mounting my Dirt Grips on my new bead locked wheels. its pretty easy to mount wheels on these things. longest part of it is the criss cross bolt torqueing process. im very happy with the results. tires are 38-15.50 16, rims if you didn't see them in a earlier post a couple of weeks or so ago are 16x12 weld SS II's that i had bead locked by OMF. i didn't buy there bolt "domes" that protect the bolt head from damage cause there 30 bucks per wheel for 12 that you put under every other bolt. i bought a 6 ft piece of 6061 aluminum for 30 bucks that will make enough for almost 10 wheels, so i will have plenty extra as they get damaged on the rocks. there 138 lbs, the rim was 30 lbs. is that a heavy tire?
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Nice. Those look sweet. I have heard that PJs are heavy tires. How did they balance? What is the true OD of the tire now that it is mounted?
    :thumb:
  3. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    looks nice. I thought those rims were going to be mounted on those pitbulls?
  4. rdn2blazer
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    I have not ballenced them yet i have three mounted and inflated, the other two i will do this weekend. i found out its much easier if you let them sit out in the sun and get a bit soft before you mount them. true od is just at 38 in. i forgot to post that pic.
    smokkey, i have had these tires for a long time.
  5. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    opps, I was thinkin of someone else....
  6. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    those looks sweet
    whats the actual weight of them cause a 38.5 bogger weighs in at about 90 lbs...
    LUKE
