mounting 700r4 to 203/205 doubler
Discussion in 'The Garage' started by ryanstrucking, Apr 13, 2005.
  1. ryanstrucking
    ryanstrucking 1/2 ton status GMOTM Winner
    Feb 2, 2003
    182
    Calgary AB Canada
    I just picked up my doubler and was in the process of installing when I came across a problem. I can't get my 203 to mount up against the 700r.
    the splines are the same, and I have the 350t mount on the back of the tranny but the 203 is bottoming out 1"-1.5" from mounting to the adapter plate.
    Wondering if anyone on here has done anything similar and if so, what did you do to make it work?
    Any suggestions or help would be awsome.
    Regards
    Ryan
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you will need either a new output shaft from advanced adapters or you will need to get a spacer that goes inbetween the tranny and the adaptor. The spacer will be chaeper but with a doubler you would be better off to use the short shaft. But for the shaft to be put in you need to take the tranny apart.
  3. originalspanksta
    originalspanksta 1/2 ton status
    Jan 31, 2005
    147
    Philadelphia
    yeah, what he said.
    Further clarification: 700 and 350 outputs are the same spline, but the 350 shaft is like an 1 1/8 inches shorter ( i think)
    I've heard of people cutting the excess length off the stock 700 shaft, but i dont thing i'd try that myself.
    Also: the advance adapters shaft has several upgrades as far as oiling holes and strength that eliminate most of the problems people have with weak 700's
  4. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,620
    609
    Hooper, Utah 84315
    Third the first answer and second the second the shaft is only about $150 and I had mine put in for about $60. There is no problem with running the spacer just makes the whole set up longer. You can cut the spines off but from what was able to find out when I was doing mine its a real pain thats why I went with a new shaft. I think the spacer is about the same price as a new shaft also.
  5. ryanstrucking
    Feb 2, 2003
    182
    Calgary AB Canada
    Thanks for the input guys.
    Looks like I'll be pulling the tranny now to replace the output sfaft as I don't have the room to ad the spacer.
    regards
    Ryan
