Mounting a cage
Discussion in 'The Garage' started by wayne, Jun 21, 2006.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Just wondering what everybody thinks. Should I weld my floor plates in or bolt them in.
  2. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    Are you going to sandwich the body and then run the cage to the frame?
    Well either way... I would recommend bolting. But I would definately put a bottom plate so the bolts will never pull through the body.
    That is what I am going to do on my cage.
  3. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    It will get tied to the frame. I had planned to plate the top and bottom and was considering running the tube through the floor.
  4. pin_it_to_win_it
    pin_it_to_win_it Registered Member
    Jun 21, 2006
    94
    centeral coast california
    i would bolt it in just in case u need to remove it. bolting it would make it easyer.
  5. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    I would bolt and put bushings in-between the fame tie in and the body you want to maintain a little frame flex between the body and frame.... Adding the support plates to on the body is good tie the body and cage togather.... But tie'n the cage to the body is a great plan. Cutting holes throught the floor to run to the frame. is another place for fumes, heat, water, rust, weaken the body....
