mounting an antenna to the removable top..
Discussion in 'Communication (CB | GPS | HAM)' started by 5150_BEAST, Dec 30, 2005.
  1. 5150_BEAST
    5150_BEAST Registered Member
    Oct 9, 2005
    62
    Los Angeles
    ive been dealing with cb radios for 5 years now but now im in a bind of where to mount the antenna with the least amount of deflection...i thought about mounting it as far back as possible dead center above the rear bumper like i always have with past trucks, but mounting to the fiberglass top...do any cb experts have any ideas on grounding or mount ideas?,most the guys i talk to have never mounted an antenna to a fiberglass top...any input would be greatly appreciated as im digging out the big drill bits and marking a place to drill a hole in the top:hack:
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have mine dead center of the steel roof .
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Is this for your 79 ??? I mounted a 102" with heavy duty spring on a light bar on the roof of the 76 K5 I had. Ran a ground strap to one of the topper bolts. Worked pretty well if I do say so myself.
  4. 5150_BEAST
    Oct 9, 2005
    62
    Los Angeles
    Antenna Mounting
    well i used to "tee hunt" and want to do it again and for the best directional readings you mount the antenna as far back and centered so my question would be would i be safe mounting it on the glass top and just running a big ground strap from it to the frame? the reason i ask is i know glass,and fiberglass have a real bad deflection problem and hinders signal output
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
  6. 5150_BEAST
    Oct 9, 2005
    62
    Los Angeles
    antenna mounting....
    naw man....that thing looks just plain stupid....gonna stick with the tried and proven,smackin cars when i turn a corner fast simple as poo 102" steel whip:saweet:
  7. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    If you want it to be directional, then go for mounting it in the fiberglass. Just be sure and make a good brace for the mount so it won't crack the fiberglass. Then you will need to make a new groundplane. The easiest way is to use metal tape. (like what is used for AC ducts etc) Run several strips along the inside of the top from the underside of the mount.
