Mounting Big Tires
Discussion in 'The Garage' started by mountainexplorer, Dec 12, 2002.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Where do you all go to have larger tires mounted and balanced? And what does it usually cost?
    I recently had a set of 38x15.50-15 Swamper Radials mounted on 15x12 wheels at a local tire shop for $50 (not balanced). They know me pretty well there, so I get frequent customer "deals" once in a while.
    Now I need to get a set of 18.5/44-15 Gumbo Mudders mounted on 15x14 wheels, but I don't know if they'll want me to bring them in.
    What sort of balancing machine does it take to balance 44's?
  2. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    I had schwabies mount and balance a set of 38.5 / 14.5 SX's for $40 a peice, but i had to take them off cause they wont touch anything with a body lift, for liability.
  3. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    I always mount them myself with a couple of really big screwdrivers. I lube up the tire bead then slowly work my way around with the "irons." I'm not sure about balancing because mine aren't.
    Will
  4. mountainexplorer
    Nov 14, 2001
    4,903
    I've done that before with 16.5's, but the last 15" I tried doing myself I think I gave up on, and it was only like a 31x10.50R15 .
  5. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    We just use a can of starting fluid and a match /forums/images/graemlins/shocked.gif!
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Bigger tires are easier to get on the rim than smaller ones. I've mounted a bunch of BFG 35x12.5x15 Mud-Terrains on 15x10 steel wheels right on the floor of the garage. /forums/images/graemlins/cool.gif Lube 'em up good then start working the tire onto the wheel. I can usually get the tire on the wheel by just jumping up and down a bit right near where the bead is sliding over the wheel. Work your way around until the inner bead pops around the wheel, then start on the outer bead. I can mount one in under 2 minutes now. /forums/images/graemlins/thumb.gif
  7. bigjbear
    Feb 18, 2000
    13,973
    454
    Marietta GA
    The radials are easy, but bias ply tires like he is talking about are a bitch. They'll go, you need to put a little ass behind them, though. I've done some big tires on my machine and I've got to say Swampers are hard to streach.
  8. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    You should send Shaggy or Savage1. They've used bee-bee's or mouse balls (computer mouse)...
  9. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    Most people I know that run 38's and up have em powder balanced at a shop that does tractor trailer tires. The shop usually has machines big enough to mount em too.
  10. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I sold the 38's I had with the BB's. It took 2 guys with a crow bar each to mount my 42's. It was pretty easy once we got the system down. I used Equal to balance them, they do pretty good up to 70mph. To seat the bead I used a ratcheting strap to squeeze the tire onto the rim. Most places wouldn't even touch that big of a tire, and the ones that would wanted around $150.00... **** that, I did it myself.
  11. 74beater
    74beater 1/2 ton status
    Sep 20, 2002
    242
    ELGIN ,TX
    TRY A BIG RIG TIRE STORE
  12. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I always wondered about that becaue someone told me a long time ago but how is it done? /forums/images/graemlins/confused.gif
  13. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Buy Hummer wheels, then they're easy to install. /forums/images/graemlins/thumb.gif </font color>
