Mounting Boggers To Rims?
Discussion in 'The Garage' started by JUNIOR-K5, Jan 13, 2007.
  1. JUNIOR-K5
    JUNIOR-K5 1/2 ton status
    Dec 20, 2005
    387
    SO.CAL
    I just mounted my boggers to my rims with two pry bars but I accidently slit the bead on one. My question is will that affect the tire at all its just a little slit nothing major. Just want to know if it has happened to anyone.
  2. gmcjimmy88
    gmcjimmy88 1/2 ton status
    Feb 10, 2005
    559
    Fayetteville North Carolina
    I have had it happen before. No major problems from it other than getting the tire to bead. This was on a street vehicle so I dont know how it may be affected with lower tire pressure. Good luck
  3. Blue90
    Blue90 1/2 ton status
    Aug 27, 2004
    583
    You might run into a bead leak as well. If that does happen just run tha tire down to your local discount they'll slap on some sealer for ya. (free of charge)
