mounting extended brake lines
Discussion in 'The Garage' started by johnathan, Feb 26, 2006.
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    When I installed my lift a while back,I ordered the sleel braided ext. brake lines from ORD. They where Pro Comp I believe.I mounted them to the top of the fender well with just the little guides.That didnt look like enough slack so I have mounted them to the shock.Does anyone have any pics showing the best way to mount them
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I just zip tied them with a small zip tie to the fender. That way the zip tie (hopefuly) will give out before the brake line if they ever get over extended. That and I'm lazy.
