Mounting hummers on DRW hubs? Center doesnt fit...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Oct 18, 2003.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    PIC #1 - shows the hub without the rim on it:
    PIC #2 - shows the rims sitting on the hub... and shows how the hub doesn't fit in the center of the rim:
    Anyone out there know if its standard practice to have to ream out the rims to get them to fit over the hubs? Its off by a VERY small amount... I could just woller out the hole a little bit... but I was hoping that there was a better solution... All help appreciated! /forums/images/graemlins/thumb.gif
    -Dan
  2. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    Dan, I had no problem mounting my 12 bolt style hummer rims on my GM D60 Dually Hub. What kind of Dually Hub is it that you are trying to fit it on? I have access to an 8 bolt Hummer rims. I will see if there is a difference in the hub opening.
  3. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Its a FORD DRW hub... from a late 70's F350 AFAIK. /forums/images/graemlins/confused.gif
    -Dan
  4. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    Dan
    Yes that is common.
    The wheels have to trimmed for the dodge axles also.
    You could also turn down the hubs. ( two hubs versus 4 wheels).
    Also check the rear depending on what axle you are running you may have the same problem.
  5. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    I'd have the hubs turned down slightly...
    Rene
  6. bpiccioni
    bpiccioni 1/2 ton status
    Aug 11, 2002
    187
    Eugene, OR
    Arent most lugs self centering? If so, wouldnt the lip on the hubs be unnecessary? Sure, they might make it easier to get the wheel close to center when mounting, but necessary?
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Those lips on the hubs ARE necessary. They hold the lockout hubs to the proper distance and keep them from sliding in and out. /forums/images/graemlins/wink.gif /forums/images/graemlins/thinking.gif
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Rene
    Same here. If there were no machine shop nearby, and to cut down on costs, I would take them to any rotor/drum turning shop and have them turn the hubs slightly. /forums/images/graemlins/thinking.gif
  9. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    AHA, got bit by the ford curse yet again!!! /forums/images/graemlins/rotfl.gif
  10. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Damn Newbie!! j/k
    When talking to "old timers" ie:(wheelers from the '80s), when they would buy new wheels, they would always buy Ford wheels. The center hole is larger on the Ford. If they ever needed to sell the wheels, they had a more "sale-able" product.
    Bit by the Ford bug again.....heh,heh,heh.
  11. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    All good in the end. I'll just ream a little outta the center on these hummers... machining the hubs sounds too much like time, money and WORK. Screw that.
    Oh, and Todd.... [​IMG] You're coming out to the 8th right? (we hope so anyways...) we'll see how my rig does with its new upgrades! /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
    -Dan
  12. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Hey man, actually machining the hub will be much less work, time and money. Do like they said, take it to any parts store that does brake rotors. Look at it this way, what if later you decide to go with a different rim with same offset. Then its grind time again!
    Do the hubs so its a one time thing. Make sure you locking hub also fits just to be sure. /forums/images/graemlins/thumb.gif
  13. laketex
    6,220
    North Texas
    no kidding....I was thinking reaming the centers of the rims out sounded insane compared to how easy doing the hubs would be...but dammit Neil, I wanted to watch him try to ream the wheels out himself. I cherish the comedy I get out here in Yankeeville watching Yankees do stuff backasswards....You're messing up my fun time! /forums/images/graemlins/rotfl.gif
  14. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    How do you figure? All that need to be done is to open the center of the hummer rim up from ~4" an additional 1/16-1/8"!!! What makes that so difficult?
    No brake shop is going to turn down the actual HUB for me... they would freak out! I can hear it already... no we CAN'T DO THAT! Thats not what the machine is for!!!
    If I get it done, I need to take it to the "real" machine shop here in town, and let them charge me out the bunghole. Not to mention, it will probably take them a day or two to get it done (they're always back logged)!
    Perhaps I missed something? I can't argue too much. I know it would be "better" to have them turned, but I don't think it will be less time consuming or cheaper to have the hubs machined at all, IMO.
    And as for you... I'm gonna take a leak in your 465 when I get home! Glad I can entertain you! /forums/images/graemlins/rolleyes.gif
  15. laketex
    6,220
    North Texas
    maybe if you got a scotch brite pad and got all the rust off them, it'd fit like a glove? /forums/images/graemlins/rotfl.gif
  16. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Whatever faaawker - You got a chip on your shoulder today. Go get laid, until then... I don't wanna talk to you. BASTID. /forums/images/graemlins/rolleyes.gif
  17. laketex
    6,220
    North Texas
    hahahahahahahahahahahahahaha
    GOTCHA /forums/images/graemlins/shocked.gif /forums/images/graemlins/rotfl.gif
  18. thatK30guy
    Jan 12, 2001
    32,076
    55
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    You two sound like an old married couple....and I don't want to know who is the husband or wife! /forums/images/graemlins/ignore.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  19. laketex
    6,220
    North Texas
    DAN IS MY BITCH. /forums/images/graemlins/eek.gif
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Good, and you're mine. Come grind my '60 or something. It's been waiting since July when I bought it man. /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
