mounting ideas? will this belly pan mounting work?
Discussion in 'The Garage' started by BranndonC, Sep 19, 2005.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    this look like the best way to mount my belly pan/side plate? the top bolt will be mounted on the flat part and away from rocks, as will the side bolt
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Maybe im just retarded but I cant figure out your drawings :confused:
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    the 2 squares are 2x2 1/4 wall square tube welded together to make a strong 2x4, the C looking thing on the right is my frame, the part under it is my skid plate/belly pan, and the piece connecting the skid plate and square tubing is just a side piece
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Ow ok so you are going from the rocker to the frame to the belly skid??
  5. captaininsano
    captaininsano 1/2 ton status
    May 4, 2004
    233
    Bay Area, CA
    I think I am a retard too... :(
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I got it . The piece that touches the rocks will have holes drilled for the bolt to pass through , the socket for removal can pass though it too . the bolt holds the bent part on the backside to the sliders and frame :D
  7. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    You could make your life a lot easier by building that upper mounting flange a little longer and mounting that bolt from the inside instead.
    It will sit flat that way, and won't get "massaged" by rocks.
