Mounting position of shocks.......
Discussion in 'The Garage' started by jwduke, Nov 30, 2003.
  1. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Ok guys......Does it make a difference a difference if you mount the shocks, with the rod up or down? Whats everyone's thoughts on shock boots? I mounted my new front schocks the conventional way, rod up. /forums/images/graemlins/thinking.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    most shocks need to be mounted rod up. High end shocks can be mounted either way. My Bilsteins will be rod down. Lower end shocks it has something to do with the fluid and all they just won't operate properly with rod down. As for boots, I won't run them. With rod up they will let mud sit around the rod and maybe get into the shock and ruin it.
  3. jwduke
    Aug 25, 2001
    721
    Alan, these shocks are from Tuff Country (RSX-8000). The mounts could be put in either end. The shocks are not marked as to which end is up. I'm in agreement with you on boots, but wasn't sure. I can never keep the stupid things on. Thanks..... /forums/images/graemlins/thinking.gif
  4. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    High end shocks are mono tube, gas pressurized shocks. These shocks do not need to be mounted either way because they have dividing piston between the gas and fluid to keep them from mixing. Cheap shocks arent mono tube and need to be mounted with the body down so they work properly.
    Many people with Bilstiens or other mono tube gas pressurized shocks mount the body up so that they have less un sprung weight and less of a chance of the body being damaged off road.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    your RSX-8000s are designed to be body down, they should tell you that kind of stuff. I will be running Bilstein 5150s all the way around, $110 a shock, body is going up and away from danger.
  6. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    $110 each? allpro off road has em for $90 each. save some coin bro.
    -Jeremy
