Mounting ram to steering stabilizer bracket
Discussion in 'The Garage' started by 8_YOUR_H2, Mar 1, 2006.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    So me and a friend are mocking up the hydro assist and he thinks it would be a good idea to use the bracket on the axle tube that the stabilizer bolts to. I Say no way it would never work, only because I have never seen anyone else do it that way and wanted to sound like I am some master fabricator but really I am a dumbass.
    He says why not...the bracket is fairly stout looks almost like 3/16" which is what the tab thickness is. I think...well ok maybe it could work, never said that out loud though.
    Anyone ever seen a hydro assist ram mounted to the OEM steering stabilizer bracket on the axle tube?
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    i dont see why it wouldnt work. maybe put another tab above the one thats there so it grabs both sides of the ram... other than that it should work fine.
  3. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Perhaps a gusset or two would be a plus (there's usually no harm in overbuilding), but I'll have to look at it when I get a chance.
  4. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    the prob you will run into probably is the distance, you have to have that ram on the axle end really close to the pumpkin to have enough room to put your mounts on the tierod. Measure twice, cut/ weld once.
  5. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Ditto. Looked at the same thing when I did my ram. I couldn't get it to work.
    Eric M.
  6. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    I mounted my full-hydro ram there and it worked fine. It took some reshaping and a few gussets, but it was a good place to start.
  7. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    Did you use the hole in the tierod too?
  8. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    How well do rams hold up on DD in winter road environments found in northern areas where they salt and sand the roads in the winter?
  9. petryshyn
    petryshyn 1/2 ton status
    Jun 6, 2004
    150
    Yorkton,Sk
    I am sure they would hold up the same as a shock in that position, so I assum just fine.
  10. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    It looks like he did. I've heard of a lot of people running it this way with no problems.
  11. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I wouldnt want that ram in single shear. Thats alot of force being applied to that 1/2" bolt.
  12. DougK20
    Feb 18, 2003
    384
    Boise, ID
    It's bored out to 3/4" with grade 8 bolt. I'm not worried about it one bit.
