mounting shock towers
Discussion in 'The Garage' started by randy1, Apr 10, 2006.
  1. randy1
    randy1 Registered Member
    Dec 24, 2005
    6
    white rock
    im putting ford shock towers on my blazer and was wondering if i should leave the bottom shock mount the same or does that have to be changed to.
    Also im swapping out my manual and putting in turbo 400 and ive got 350 now but want to go to 454 shortly down the road and was wondering if i have to change anything to get it to mount up to 454.
  2. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    Try to make the shock travel match the suspension travel.
  3. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    here's what worked for me. My lower mounts were fine.
  4. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    How much lift ya got Randy? Maybe someone with similar setup will chime in with the right shock length for your lift with the Furd towers.
  5. randy1
    Dec 24, 2005
    6
    white rock
    ive got 6 inches of lift and got some ranch 9000s with 14 inch of travel im not sure there exact length at 35 inches i think it looks like im gonna have to use all the towers and mount the bottom pretty low ill figure it out thanks for replying
  6. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    Don't go so low you hang 'em up on stuff.
