mounting shocks in front of the rear axle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by camiswelding, Dec 9, 2004.
  1. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    Anyone see a problem mounting shocks on the leading edge of the rear 14b... using a crossmember similar to MO off roads? (I am aware their setup does not put the shcoks at optimum anles)
    Im trying to get as much room aft for a between the rails tank conversion...
    anyone done this?
    thanks
    cam
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    This is a fairly common problem/solution, so I'm moving to 2nd Gen.
    What you describe has been done lots of times and there should be no problems at all, except for those you seem already aware of. Good luck...
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Both rear shocks on the front side of the rear axle? This is stock on a 1st gen...at least the mounting on the axle part.
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    If I remember right alot of fords run them like that in the stock form (both to the front) so I can't see any problems with that, they're just there to dampen the ride ( slow the spring rebound)
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yeah, the only thing you really loose (as opposed to staggered) is marginal axle-wrap control. Not worth worrying about if you need the space.
  6. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    thanks men of ck5!!!
  7. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Here's a couple pics of mine. I have been running them for a couple years now with no issue. The adjustable Rancho are nice when you inboard the shocks like this...
