Mounting shocks with rod ends
Discussion in 'The Garage' started by mrk5, Mar 15, 2007.
  1. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    I'm getting new shocks for which I'm fabbing mounts. They use rod ends and I'm wondering if anyone has some installation tips?
    I know I need to account for several factors like arc of travel due to suspension movement. Also figure I may need to account for some axle wrap in the rear.
    I'm wondering if I need to make spacers for either side of the rod ends between the ends and the tabs. I was thinking the spacers would help provide clearance between the ends and the tabs if they are at angles to each other.
    I'm figuring on welding the tabs on the axles so they are perpendicular to the axle tubes. I think especially on the rear this will help with any potential axle wrap; meaning I don't want any axle wrap to damage the shocks.
    Any tips or pics would be appreciated.
  2. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    I have 14" travell fox 2.0 ext res shocks for my front with rod ends. I got a handfull of spacers to go with it to make the mounts alittle wider so the shock clears the tabs when it moves some.
