Mounting the batteries in the rear.
Discussion in 'The Garage' started by Sandman, Dec 10, 2002.
  1. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I'm thinking of moving the batteries to behind the rear wheelwells. Anybody do this? Pros, Cons? Thanks.
  2. pilgrim
    pilgrim 1/2 ton status
    Sep 10, 2001
    247
    new hampshire
    yes i hace given this some great thought. i was planning on mounting two batts in the rear spare tire carrier. i'd spend some time and really mount them good in a well built box/bracket set-up. one of the things about DC current is that the longer the run of wire the heavier the needed gauge of the wire. say your increasing the length of your cables by 12 feet, you might need to thicken them from 4 gauge to 0 gauge (1 ott). of course the safest thing to do is to add up all your electrical needs and then build your cables accordingly..
    I also was thinking of mounting two batts under the drivers seat. I'd do this by cutting out the hump and building a box down inside the body. i really want to get my batts out from under the hood, so i can really cut up my fenders.. /forums/images/graemlins/grin.gif
  3. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I was thinking about doing it for the weight transfer to the rear. Summit sells a kit with a long cable. Maybe I'll do that. I was thinking one battery on each side but it might be easier to have next to each other.
  4. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    I will be mounting my batteries in between the front seats, but pushed all the way back with a battery selector switch too. I carry too much stuff in the back already.
  5. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    If I was going to put them back there I would use 2 ott cable the bigger the better. And less strain on the battery
    Eric
  6. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Just curious but why? Seems like a pita to route the cables and the cost of that size cable would not be chaep.
  7. 86K5TrailBlazer
    86K5TrailBlazer 1/2 ton status
    Apr 24, 2001
    436
    Orange,CA
    if given this alot of though . I am planning on two batteries each right behind the front seatbelt(boxes?) In Moroso sealed boxes /forums/images/graemlins/wink.gif.
    And run 00 wire all around with hellroaring iso etc.
    why?
    well gain room in the engine compartment.
    weight distribution ( yeah i know but every bit counts!)
    im sure there are some others too /forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/tongue.gif
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I am looking to drop down some of the weight off of the frontend. My rear with disk bracks and the softop is way lighter than the front. I am looking for the lighter front end for mud racing and in the deep snow the front always sinks and the back stays high. The batteries are just one approach. I also would like to make my inner fenders easier to remove. If I could have 'em in there with just a few bolts I would remove them for engine work and whatnot. With 9" of lift, It would be worth the effort.
