mounting
Discussion in 'Audio' started by Confederate9, Jul 19, 2000.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    how do i mount a new pioneer system in my 85 k5 when it doesnt have knobs and stuff liek the stock stereo.
    whould i mount it somewhere else? if so how do i do that. shoud i spleit the wires and have 2 radios or go w/ 1
    '85 K5: BIG BAD AND MEAN
  2. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    On my dad's old truck there where holes in the metal where the knobs were. We had to cut out the metal so the stereo would fit. You might want to go ahead and buy the mounting kit so you can find out what needs to be cut and what doesn't.
    89 K5 Silverado
  3. imconfused
    imconfused Registered Member
    Jun 16, 2000
    44
    I ran into the same problem until I found out that CRUTCHFIELD carries a trim plate designed just for this install. I wish I could post a photo but.. I assure you this will look great compared to most "HACK" jobs that I've seen . Unfortunately it cost $10.00 plus $4.95 to ship but still well worth it.
  4. **b**
    **b** 1/2 ton status
    279
    KIllington, VT.
    If you value your interrior...
    spent the 50 bucks and have it installed....
    You any good w/ a Sawzall???
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I had a new Clarion deck installed last fall in my 84, and I sat with the tech while he installed it. As far as I'm concerned, it was the best $50 I ever spent........it took the guy an hour, and when it was done the deck looked like it had always been there!
    He had to trim the sheet metal to fit the deck in, and there was a lot more to pulling the factory unit out than I imagined. You might want to add to b's post above "if you value your back"- the whole experience looked really uncomfortable, too.
    BTW, the shop included the trim ring in the cost of the install.
  6. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
  7. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    --Metra makes a dash kit, part number 87-99-3052, it has a metal plate and an abs plastic trim that fits nicely. It is the way to do it. I do them quite often and have found the kit makes life easier.
    89 w/DANA 60-Corp 14 w/5:13s n Detroit's. 4"lift 2" body. NEW AtlassII being installed
  8. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Ask K573 he is a pro-installer he always has good ideas.
