Move rear axle or leave it stock location?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Oct 16, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    It looks liekthe consensus is to move the front axle 1.5" forward for better alignment in wheelwell.
    What about the rear axle? Move it back some or keep it where it's at?
    -- Mike
  2. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Since /forums/images/graemlins/k5.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/truck.gif have such bad departure angles, moving the rear axle back helps a lot. After a shackle flip, it also helps to move the rear axle back into the center of the wheel wells, although it is not that far off. On a /forums/images/graemlins/k5.gif about the max you can move the rear axle back w/o hitting the tank is ~3" I think. /forums/images/graemlins/confused.gif Don't quote me on that one. Don't know about /forums/images/graemlins/truck.gif.
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    As was said earlier, moving back helps departure. You can also cut the bed sides back (like moneypit) to dramatically help.
    On my rig, I have almost a 90* departure and I'm running a small K5 tank mounted higher than stock (about 2" above the frame). I built a cross member at the front of the tank that has a bump stop mounted so that the axle can not hit the tank. This provides me with up to 6.5" of up travel at the diff with much more on the sides available for articulation...
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    What did you have to go through to raise the tank? I have been thinking about doing this.
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Well, remember, I was converting a K30 to use a K5 tank so, I had to do everything from scratch. However, I used cross members from a Suburban so it would be much the same for raising the tank on a K5.
    Basically, cut the rivets out of the tank cross members and remove them. Then, notch the ends at the location where they will fit over the frame lip, build a "leg" to stabilize the bottom, and a bracket to tie the top to the frame. Here is a pic of my front tank cross member installed, you will need to do something similar...
  6. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
    To raise it up about 1", you can cut and splice the straps holding the tank up. Then modify the skid plate to match. Don't know how to get it up much higher than that with out Viagra.
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I'm confused, how is that possible when the tank fits up in the "cup" formed by the 2 cross members? /forums/images/graemlins/confused.gif
