Moving axle froward & swaybar???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by grtwhite, Aug 2, 2003.
  1. grtwhite
    grtwhite 1/2 ton status
    Aug 3, 2000
    366
    Macungie, PA
    I'm in the process of moving my axle forward 1.5" with zero rates and having a hard time getting the u bolts straight with the swaybar. I also installed longer shackles up front and loosened the sway bar bolts. Has anyone else run into this prolbem or have I done something wrong.
    Thanks!! /forums/images/graemlins/thumb.gif
  2. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    You're prolly not going to be able to run that sway bar...unless you also move the upper sway bar mounts 1.5" forwards.
    Rene
  3. grtwhite
    Aug 3, 2000
    366
    Macungie, PA
    Rene,
    Thanks for the quick response! I was afraid that might be the only option. /forums/images/graemlins/pimp1.gif
  4. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    If you run the ORD swaybar discos it might work. It will work w/ the 1" offset.
  5. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i have found my swaybar 100% useless, all it does it hinder my flex.
  6. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    word
  7. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I threw my sway bar out...haven't had one for almost 4 years now./forums/images/graemlins/grin.gif
    It really depends on how soft a front spring you run though. My Rancho's don't need help keeping the front level through a corner...maybe I'd feel the need for a sway bar if I had some Tuff country EZ rides though.
    Rene
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Me too /forums/images/graemlins/grin.gif It limited flex and made a racket since the bushings were all pounded out. /forums/images/graemlins/rotfl.gif Even with stock 3-leaf springs I found it decent on mountain highways. Took a couple of corners to get used to it, but that's just like driving anything for the first time. /forums/images/graemlins/wink.gif
