Moving em forward
Discussion in 'The Garage' started by sled_dog, Feb 25, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Alright I want to know what happens if I move the front axle forward with a zero rate. Want to get some more clearance. Does this effect steering at all? Anything else I need to know?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    What it does is keep your tires from kissing the firewall when your suspension is in compression and steering turned.
    As far as what needs to be done/changed (from what I understand): you'll have to make your draglink shorter (just adjust it smaller) and you won't be able to use your sway-bar, unless you've got ORD's sway-bar disconnects.
    Oh, and you'll get 1" of lift, too. /forums/images/graemlins/thumb.gif
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah I know 1" of lift. THing i don't like about that is I bet I will need a new driveshaft. 5" of lift and pushing the axle away from the Tcase, at least I need one of those shaft spacers. Wouldn't I?
  4. heavy4x4
    Aug 28, 2002
    3,270
    Maybe I'm going crazy, but I could swear I read on here not too long ago that someone's running a 4" (maybe 6") lift, the ORD zero-rates (+1") and axle moved forward 1" - and all he had was the stock front shaft and a spacer. If that was YOU, speak up! /forums/images/graemlins/grin.gif
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yes please do cause I am really considering this.
  6. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    i'm runnin 4" springs hill4wd shackles and a 1" spacer. sorry no zeros though.
  7. heavy4x4
    Aug 28, 2002
    3,270
    Well, seems ColAdo82K5 has a "similar" setup. Maybe that's what I'm thinking of...I don't know. BUT, you'll most definitely be better off having yours extended. No doubt you'll be pushing the limit of that d-shaft with that setup even with a spacer. That will lead to short slip-yoke life/accelerated slop. You could also probably find a front driveshaft from a different truck (with a different tranny/t-case combo) that measures longer than yours and put that in there.
  8. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Hey guys,
    I have a spacer with my stock from shaft and i have a 350/208 setup. But to tell ya the truth, my shaft might be from a 700/208 setup because my truck orignally came with that from the factory and i don't know who did the swap. (the 700 should be longer due to the added length of a 700 compared to a 350) To tell ya the truth, I've never thought about what setup my shaft is really from. BUT currently I have that shaft with a 1 inch spacer and a 6 inch lift. I have flexed it out fairly well on a wall and the shaft seems to do fine and i've never had a problem with it offroad. (no sway bar) I would say go for it.
    BUT !!!! I worry about your steering more than anything....making your graglink shorter than it already is might cause some more bumpsteer or problems to that extent.
    Blake
  9. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    I have 4" springs, 1" ORD zero rates and tghe axle moved forward 1". I had to run about 5 washers on each one of the bolts that bolt the drive shaft to the t-case (to space it out a little bit). I did have to adjust the steering however, and it came so close that if I had moved the axle 1.5" forward then the drag like would not have worked because the two Drag link ends would have hit. So mint came out pretty good. Once I get my Dana 60 in though ot will push the drive shaft back to where it should be because they are a little longer from the diff cover to the yoke. Hope this helps. Later
    -fLeXy K20
