Moving front axle back
Discussion in 'The Garage' started by 1979jimmy350, Aug 23, 2006.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    I need to move the front axle on a s-10 back about 5 inches after the SFA conversion, would i be better off to move the front schakels, redrill the springs or use a add a leaf. I am using 4inch lift springs for a k-5 as the springs.
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    why do you "need" to move it back?
  3. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    i would like to center the axle more in the wheel well so i do not have to hack the fenders a ton
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    you'll likely run into the floorboards. what size tire are you running?
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    move the front hanger and then move the shackle back. you would prolly be better off keeping it the way it is. you gatta be careful bout firewall contact etc.
  6. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    i am keeeping a eye on the firewall clearence. I have no idea what size tire hes running yet, the truck is a s-10 blazer sitting at about 10 inches of lift with a SFA. The front axle center line ended up being farther forward then i would like it
  7. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    what axles are you running? got any pics? sounds like it is sweet
  8. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    here is a few pics of the truck, in the front is a D44 eight lug, the rear is going to get a 14blt ff. the tires on the front are only 31s, i my buddie should be able to fit at least 35's under there.
  9. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    looks like you can turn the springs around. might be just the picture though. you wont get 5" but it'll be better.
