Moving front axle forward, shims
Discussion in 'The Garage' started by Hardcore, Mar 28, 2005.
  1. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    Okay, so I drilled new center pin holes 1" offset on my Dana 60's spring perches so I can move the axle forward. The only problem is my 6" BDS springs have shims that need to be installed. If I bolt them into the leaf pack like it says then they will be offset too....How did you guys get around this :confused: The only thing I can think of is to drill another hole in the shim 1" offset and bolt it in like that but I'd be putting a hole in the thin side of the shim and I'm worried I'll break them eventually and spit them out :blush:
    How are you other guys doing it?
  2. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    TTT anyone???
    Should I just forget the shims and run without them??? :confused:
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    If you've got steel shims, I wouldn't worry about drilling another hole. I move my front axle forward 1.5" using offset degree shims.
