Moving frontend forward...Mess up...?
Discussion in 'The Garage' started by Ben B., Oct 8, 2005.
  1. Ben B.
    Ben B. 1/2 ton status
    Sep 1, 2005
    352
    Central PA
    I'm looking at purchasing some 1" Zero Rate Add a leaves from ORD to move my frontend forward an inch or two.
    Will I need to lengthen my driveshaft or should everything be alright?
  2. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    how much lift do you have? the ORD zero rates only move the axle 1" or 1.5" so if you dont have much lift you should be able to get away with 1" and maybe 1.5". if you dont have cross over you will have to adjust your draglink so your steering wheel will be straight.
  3. Ben B.
    Sep 1, 2005
    352
    Central PA
    4" of lift.
    Not too concerned about the steering, i put my truck in a ditch hard and messed that all up, so it can't get much worse. But no, no X-over.
  4. PsychoticDeadGuy
    Jan 8, 2005
    753
    it should be fine. I have 4" of lift in the front of mine with zero rates and i was going to move the axle forward...i pushed it forward and i didnt see any splines on the 2 piece shaft so it could have been good. i didnt do it because i didnt like how it looked...
  5. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    What is the advantage of moving you front axle foward? Would'nt it be easier and better to do the rear?
  6. PsychoticDeadGuy
    Jan 8, 2005
    753
    better approach angles...
  7. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    As well as better clearance for bigger tires. It's a little hard to trim that firewall back .. even just a bit. ;)
  8. Ben B.
    Sep 1, 2005
    352
    Central PA
    Yeah, my goal is to fit 38.5x11 Boggers on my K5 with 5" suspension, a 2" body and fender cutting, so the zero rate will add an inch and make clearance much better.
  9. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    i fit 38.5x15x15 boggers on my k-5 with fender cutting zero rates and 4 inch lift! only hits firewall under pritty big flex.
    LUKE
  10. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    You could get an inch by just drilling new center pin holes in your spring perches 1" behind the stock ones.
    As far as the driveshaft goes... no way for us to know. Best thing to do would be to remove the shaft and measure. I usually just measure how much spline I have in the slip shaft. Then reinstall the shaft and droop the front suspension as much as you can... measure again, see how much splines you have showing. If you're close to running out, it'd prolly be a good idea to get your shaft lengthened. It really isn't that expensive.
    j
