moving shackles with stock length springs?
Discussion in 'The Garage' started by moturbopar, Sep 7, 2005.
  1. moturbopar
    moturbopar 1/2 ton status
    Feb 9, 2005
    387
    mesa az
    Hi all , I did a search but havnt really found anything. Anyways I wold like to get more flex out of my 2.5" lift springs. what I was thinking about doing is moving the factory shackle mount forward a bit and installing slightly longer shackles. I figure doing this will make the spring act softer and will allow more droop. I plan on doing a crossover steering and run 52s when I swap in the dana 60, but that wont be well into next year, and I want to do some more wheeling now. You guys see any problems with this? here is a pic or two of my front end almost maxed (not very impressive!) I would like to get atleast a couple more inches out of it.
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I did that to my front end and it sofened up a lot. It has a bit more droop to. I would do it for the ride and put a limit strap on the drivers side. The extra droop can really hurt the ability of the stock steering to actually direct the tires.
  3. moturbopar
    Feb 9, 2005
    387
    mesa az
    Thanks! IF you dont mind me asking, how far did you move the shackle, and what length shackle?
    Shawn
  4. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    that flex isnt too bad really.
  5. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    I think they are 6.5" eye to eye. I know they are 1" longer than stock. I think there is a pic of my front shackles in my sig link.
  6. moturbopar
    Feb 9, 2005
    387
    mesa az
    Thanks!
  7. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    with 7 1/4" shackles you can move the rear mount the same as you would if you had a 52" spring swap.
