Moving spring perches...
Discussion in 'The Garage' started by OrangeCrushK10, May 6, 2005.
  1. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    Got a 1-ton rear that I'm building up. Does anyone have measurements of where I need to move the spring perches to?
    TIA! :D
  2. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,618
    608
    Hooper, Utah 84315
    Measure what your putting it into cause thats what matters
  3. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Yep, definately measure your spring distance from center to center and go from there. I am running a van width and my perches are roughly 5 3/4" away from the drum backing plates. Best to put the axle underneath and triple check your measurements and make sure it is center.
    First set of perches was slightly off by maybe 1/4" and annoyed me just knowing that. Would also be a good time to set your pinion angle at what you feel best with.
