moving the crossmember when swapping to a TH700 from a TH350
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Aug 6, 2002.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Ok, im just about ready to get going on my trans swap I am just gathering info now. When I move the t-case cross member back, should I drill new holes or just weld it on, the only reason I say just weld it is because I can figure out how im going to drill into the upper frame rail without going in at an odd angle. I know I shouldnt weld it cuz it will just end up being a pain if it ever needs to be removed.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    just drill new holes /forums/images/icons/smile.gif and why do you need to drill the top frame rail?????? /forums/images/icons/confused.gif
  3. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    because part of the crossmember goes to the upper rail, There are four bolts holding each side, two on the upper and two on the lower
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    ah sorry i was thinking of mine that only has 2 on each side /forums/images/icons/shocked.gif i would still drill it though if you weld it you will regreat it when you or the next person goes to pull the tranny
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Dude, When I lowered my T-case, I didn't bother to reconnect the bolts on the upper framerail on the passenger side, And the part of the crossmember that wraps up and around the side of the frame on the drivers side I just whacked off with the plasma cutter. No probs yet. /forums/images/icons/wink.gif So I'd say just re drill some new holes in the lower frame rail and move it back. /forums/images/icons/laugh.gif
  6. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    I used a 90 degree drill, had no problems. I also removed the rivits holding the two ends on and replaced them with bolts. /forums/images/icons/grin.gif
  7. Jay73K20
    Jay73K20 Registered Member
    Mar 4, 2002
    67
    If you don't have a 90 degree drill then go to home depot and use a really long drill bit (7/16). They cost about 18 dollars. I still haven't added the upper brackets since the conversion (lazy) and it has been about 4 months.
  8. 76chevy
    76chevy 1/2 ton status
    Aug 16, 2000
    246
    Utah
    Can you do a write up of the conversion and take some pictures? I bet a lot of us with the older trucks would like to swich transmissions the next time they go out.
  9. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    I can try, still havent started on it yet. I would like to have a trans jack to use but i may have to work without one. I have the money now to order the new output shaft for the 2wd trans so it shouldnt be too long before I get going and ill try to take plenty of pictures and remeber how i did everything
  10. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    I would drill new holes...in this hobby you never know when you get an itching to swap parts.I've already swapped out my auto to an manual and thinking of doing a different t-case.Mike
