Moving the front axle forward
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5thatShmobs, Oct 14, 2002.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    I was hoping that I could get some suggestions on a good way to move the front axle forward in my K5, as this is not something I have researched.
  2. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    What I and some others have done is re drill the leaf spring and move the center pin. Its pretty easy on a drill press. I moved mine forward 1.5" this way.
    Depdog /forums/images/graemlins/usaflag.gif
  3. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    There are several ways to do this.
    1. Re-drill center pins on springs.
    2. Use plates from M.O.R.E. to move front axle forward 1" or 1.5". They are 3/8" tall.
    3. Use Zero Rates from ORD to move axle 1" or 1.5". They are 1" tall.
    4. Order custom springs with center pin at any location.
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,387
    E-town baby!
    You could also re-drill the perch and spring plate...
    Rene
  5. jstevenj
    jstevenj Registered Member
    Aug 28, 2002
    94
    north Miss.
    Let's keep the ad's in the for sale section. /forums/images/graemlins/deal.gif
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,387
    E-town baby!
    Nice shameless plug... /forums/images/graemlins/rolleyes.gif
    Rene
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I made offset plates (like the ones already mentioned) to move mine forward 2".
  8. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Hey Russ
    Do you have any pics of the plates you made? Also what kind of steel did you use, measurements and such.
  9. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
    It is not hard to do, but sometimes I would rather pay someone $20 and not have to mess with it. /forums/images/graemlins/tongue.gif
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Nothing very interesting. Just 4 plates, cut to size, drill 2 holes in each, countersink one, spot weld a pin in the other. They are very similar to those sold by various people. Here is a pic before they were completely finished. Looks like I didn’t take one after they were completely done but this shows pretty much everything except the finish grind on the belt sander.
  11. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Forgot to throw that one in there.
  12. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    Hey Russ do you have a pic with it together?
  13. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Nothing where you can really see them, and my camera is busted...
  14. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Does moving the axle forward mess with the steering geometry at all? Do you have to do any modifications to the steering arm/pitman arm?
    Thomas.
  15. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    You can not move the axle very much without changing the drag link. With cross over, it's no problem. If you want to keep a stock config, then it depends on whether you have sufficient adjustment in the drag link. However, this will result in a shorter drag link and compound the standard problem resulting from drooping the driver's side front... I would not recommend it at all…
  16. 79Silv4x4
    79Silv4x4 Registered Member
    Aug 14, 2002
    50
    Lawton, OK
    Please excuse the stupid question, but what does moving the front axle forward accomplish?
  17. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    For me, I wanted 2 things. A better approach angle, and more clearance between the tires and firewall (I *NEEDED* it with 42s and 4" of lift).
  18. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    I did this last weekend. i move the axle one inch up bu using some homemade zero rates. The on things i ran in to was the Sway bar had to be removed and the Plates for the Ubolts had to ground out, because there was just a small whole in mine and the top of the center pin would not work with the whole when the ubolts where moved up. it was easy, just took some time. and the heads for my center pins that go into the axle are not the same as the Rear one. so we had to take a bolt and grind down the head to fit. do not forget you will have to change your steering arm if you do not have x-over.
