Moving the front axle forward??
Discussion in 'The Garage' started by 87GMCJimmy, Mar 5, 2003.
  1. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    I need to lengthen my front drive shaft anyway and was wondering how far can you move the front axle forward by redrilling the spring perchs and u bolt plates. Any problems/issues with this? I don't have x-over steering yet but will someday.
    Thanks for any info.
    Mike
  2. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Not sure about the front but on the rear I drilled my 57" Ford springs 1 1/2" back. IMO as long as you keep the old hole under the spring plates you should be fine.
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Seems like a lot of work when the zero rates are so cheap. -
    -- Mike
  4. spoolnaround
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Safer too, and by the time you spend sharpening drill bits and all thats what I would do if I had to do it all over again. /forums/images/graemlins/thumb.gif
  5. 87GMCJimmy
    Nov 21, 2001
    582
    Phoenix, AZ
    I know some people have done this by drilling the spring perches and u bolt plates and not drilling the spring itself. Yes you can go with the zero rate also but I really don't want a full inch of lift in the front. Maybe built a thin zero rate??
    Mike
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I moved my D60 forward 1.25" by drilling the perch and spring plates. I didn't want another inch of lift either...
    Rene
  7. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I moved mine forward 1" by drilling the perches and spring hold down plates. It is easy to do with no problems afterwards and it's free. One problem you may have using the zero rates is with cross over steering and drag link to spring contact, that's one reason why I didn't go the 0 rate route. I did fab some zero rates for the rear of mine that move the axle back 1.5"s.
  8. Grim-Reaper
    7,385
    Atlanta
    You can get away with an inch with the stock drag link most of the time. Much over that and your pushing it. The shorter the dragling the worse the flexed up bound up steering becomes.
  9. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    I did it with the Z-rates, if you do it that way then you might have to drill out the u-bolt plates on the top and your sway bar might have to removed /forums/images/graemlins/thumb.gif
