moving the front forward
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JunkYardCrawler, Apr 10, 2002.
  1. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    how do you move the front forward for bigger tiers?
    like an inch or 2?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Offroad Designs new offset add a leaves. They can move your axle forward or backward an 1" or an 1.5". Stephen has them under new produst on his page.
  3. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    You should be able to get an inch forward by just drilling out another spring pin hole in your spring perch! You also have to clearance the spring plate at the same time of course. This is the cheapest way to get an inch or so...I will be doing it with my D60 going in. If you need more than an inch, might want to go with the ORD offsets...
