Moving the TBI electronics to a waterproof box
Discussion in 'The Garage' started by mr.smartass, Dec 15, 2006.
  1. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    I was just thinking... What if a i built a waterproof case for the ESC, EGR sensor, MAP sensor, and Coil pack and mounted it on the firewall? This would mainly just get them out of the way and make it looked less cluttered, just extend the wires and the couple of vaccum lines and get that bracket off the intake so i can drop my air cleaner directly onto my TB without a spacer (unless it would still hit the distributor, hmm). Just a thought, has anyone else done anything like this?
  2. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    One word Tupperware:D
  3. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Hey this seems like a good idea.
    let me know if u do it.
  4. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Or if you need metal, a surplus ammo can, they're waterproof.
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    It is a hell of a lot easier to just smear them with a little silicone. Thats what i do. But they are called "water proof "connectors after all.
    If you do move them and cut any wires be sure to solder and shrink wrap ALL electrical connections and splices and wipe with silicone to waterproof them or they will give false readings. Better yet if you are that worried about that stuff... move it all inside the cab where you can lock it up and it will be safe. I hear MAP sensors are real hot on the black market these days.
  6. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    well it'd mainly be just to relocate them to get them out of the way, but you might as well take a little extra time to make it water proof, I'd just have to find a place to mount it because It's already a little crowded back there.
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    When I did the TBI conversion on my '78 I mounted everything in the glove box (is that what you call too?)
  8. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Nah! Here in the states its called the gun box.:D
  9. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Driving arund London before they took away our handguns I used to carry my .45 in a Miami Classic shoulder rig leaving the 'glovebox' free for ........., well, actually it was usually full of the wifes crap seeing as she sits on that side.:haha:
  10. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    lol, or the "no it's locked and you can't search it without a warrant or probable cause officer!" box.
  11. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Now thats neat. But is that by state?
  12. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    I don't know... I just heard that Jay-Z song "99 problems" and it says it in there but it's definately worth looking into. In the song the officer follows it with, "We'll see how smart you are when the K9 gets here" so there's always ways for them to get around it. But i'd like to find out.
    Ok back on topic, moving it all to the glove box might work, but what about the small vacuum lines on the map sensor and egr? would it mess those up with they got to much longer?
  13. dyeager535
    26,982
    191
    Is this even worth considering?
    I'm just curious as to how susceptible the sensors are to water. As mentioned all connections are water-resistant, the only piece NOT designed that way is the ECM, although Corvettes for a few years did have. If the ECM when mounted underhood required a different design, but the sensors didn't, I have to question if the sensors are really worth trying to waterproof more than maybe some grease.
    They all seem to be pretty solid/glued.
  14. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    It's more for the relocation of the coil and that bracket on the manifold so it will look cleaner and I can lower my aircleaner directly onto the TB, I've heard this can free up airflow a good bit. plus I think it'll look nice.
  15. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    I have done it before on my zuk and on other peoples rigs. Anything we thought would drown that we could mount in a tupperware container we did. Easy to work on cause you just take the lid off. We did end up having to vent at least one of them inside the cab to prevent it from heating up. It was a computer on an Isuzu trooper. BTW this was is prep for a trail where we knew we had to ford a creek that could be as deep as 5 ft. It ended up being about there and no one had any problems. It also looks kind of dumb in your engine bay.
  16. dyeager535
    26,982
    191
    You really want to be careful mounting these things in enclosed environments. Some of this stuff tends to run warm, air circulation is a good thing.
    I've got a coil bracket from a Camaro on my truck, happened to bolt right up to the (diesel fuel filter bracket threaded holes) firewall of my truck. So it's up off the intake clear of that stuff. Looks weird somewhat, but it works and I'm not trying to impress anyone but myself.
    I made a bracket that moved all the relays and ESC stuff to the master cylinder setup, which again looks odd, but is off the engine. Of course, I had plenty of spare wiring (original Camaro harness) so I could do this without lenghtening or shortening anything.
  17. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    Entirely true we used a temp gun to check the temps on all but a few things we knew would be fine
  18. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    What's this coil you speak of? My TBI conversion has the ECM and relays all mounted in the cab, and I put them in a metal box between the seats for easy access when messing with stuff. The MAP is cable tied up high on the firewall someplace. I have an aftermarket open element air cleaner right on the throttle body.
  19. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    well my TBI is stock and the coil that goes to the distributor is mounted on the intake and when i tried to lower my air cleaner down on to it, it hit the coil and the bracket with the ESC, the EGR solenoid, and the map sensor on it. I can build the bracket down but i don't like it there, and the coil still hits.
  20. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    here's your solution....
    http://store.summitracing.com/partdetail.asp?autofilter=1&part=HYP%2D4001&N=700+400318+4294925239+4294908216+115&autoview=sku
    $44.00 at Summit, and it'll do exactly what you're looking to do with removint the spacer under your air cleaner, only it'll do a better job of it.
