MPG loss 31" to 33"
Discussion in '1982-Present GM Diesel' started by woods, Mar 26, 2003.
  1. woods
    woods Registered Member
    Feb 18, 2003
    73
    MPG loss 31\" to 33\"
    Stock blazer 6.2L going to put a j-code intake once I catch up on some bills. How much should I except to lose in MPG if I put 33" on? Or should I just get 31", since I dont plan on off-roading all that to much, but 33" look a lot better?
    2 Tires im looking at:
    http://www.tirerack.com/tires/tires.jsp?tireMake=Dunlop&tireModel=Radial+Rover+A%2FT&vehicleSearch=false&partnum=105R5ROVATOWL&fromCompare1=yes#Survey
    http://www.tirerack.com/tires/tires.jsp?tireMake=Dunlop&tireModel=Radial+Rover+RV
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Re: MPG loss 31\" to 33\"
    It looks like you need to fill in your profile a little more, brother....
    Lets start with this- What gears do you have?
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Without knowing what setup you have I am assuming stock everything.
    If you move up to 33" you shouldn't loose MPG, you might even gain some. Your off road ability will decrease though.
    And if you have the early 700r4 (82-86) then you should be carefull with the shifting don't leave it in OD and it's even better if you put a trans cooler.
    The diesel have the torque down low on the RPM's so you don't use much fuel to make it run.
  4. woods
    Feb 18, 2003
    73
    Everything stock except a trans cooler, and maybe a shift kit from last owner. After talking to my brother since its an everyday driver just going to put 31" on it since 33" just going to be more wear and tear, since I wont be on the trails to much.
    Woods
