MPG with 3.73 axle gears
Discussion in '1982-Present GM Diesel' started by 84CUCV, Nov 26, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    The truck has 6.2 400/208 combo. I might be taking out, 4.56 gears and put in rears with 3.73. What kind of MPG will i get? Will i be able to do 70 on the parkway? No sure how to fugure this out on my own. thanks for the help!
    Mike
  2. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    My K2500 6.2 Burb with a th400, 3.73s and 31s could get 19 MPG if kept around 65. It would do 75 or 80 maybe but sure screamed down the road.
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK thanks mike
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    it will do it, but I dont think you'll see the fuel economy that your looking for. Take it down a few notches to 55, then you'll see 20+ . /forums/images/graemlins/smile.gif
    Leave the 456 in, put in 33 or 35" tires. /forums/images/graemlins/smile.gif
  5. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    that one thing i never thought of. thanks
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    With 4.56's, 31's and a non OD tranny you would be turning 3,213 RPM's at 65mph.
    With 3.73's and the same combo you would be turning 2,628 RPM's at 65mph.
    With your current 4.56's and you step up to a 35" tire... 2,845RPM's at 65mph.
    For the best fuel mileage you want to be around 2,000RPM's. I get 20+ at 70mph turning 1,800 RPM's with 3.54 gears and true 31's on my Dodge cummins.
    I would consider a taller tire for the cheapest route but if you really want to get the best mileage you should consider swapping to a Th700R4 or NV4500. The first gen dodge cummins 89-92 had the option of a 5 spd manual and a torquer flight 929. You got 4.10's behind the 5 spd and 3.07's behind the 3spd auto. THe clear choice is the manual but the problem was that it wasn't an NV4500 yet but a underrated LD tranny that had many problems. The TF auto worked fairly well but the high gears hurt acceleration and towing performance.
    My point is is you could gear way up but with slower acceleration as a consequince. IMHO, an OD tranny is the way to go.
  7. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    torquer flight 929
    /forums/images/graemlins/thinking.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/histerical.gif
  8. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK know a good shop for 700r4s? thanks
  9. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ] Yes, the custom shop that built mine.....but you are in NJ and I'm in Cali. /forums/images/graemlins/smile.gif Bowtie OD builds a nice 700...
  10. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    torquer flight 929
    [/ QUOTE ] /forums/images/graemlins/confused.gif /forums/images/graemlins/dunno.gif
  11. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    I do it too: should be Torqueflite 727 /forums/images/graemlins/deal.gif
  12. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Thanks i will check it out. mike
  13. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ]IIRC there was the TF727 and heavy 929 model.
  14. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    The Torqueflite 727 was the heavy duty.
    The 999 is the other one you are looking for.
    They also have a 904 light duty.
    I can't remember if the 999 was an OD or the 904 but the 727 was not.
