MSD 6A or MSD Off-Road
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by johnny reb, May 21, 2001.
  1. johnny reb
    johnny reb 1/2 ton status
    Mar 6, 2000
    326
    Pittsburgh, PA
    I don't know which one to get. My truck is used primarily as a daily driver but I do get off-road at least once a month. I'm looking for a little boost in power. I just installed a new GM 350 a few months ago, but my 33s and 3.42 gears are killing my power. I hope to regear in the future and I thought that an MSD ignition would offer some help for now. Also what is the difficulty level in installing these ignitions? Thanks
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    MSD ROCKS! I emailed MSD and asked the same question and the biggest diff between the two is that the off road version is completely submerged in that apoxy stuff were the 6A has just been coated with it. The comparison thaty gave me is you can run the offroad one under water were the 6A under water would, in time, fail. So the question is do you plan on submerging your rig in water?? Probably not. The 6a is what I bought and i like it just fine it stood up to water and mud from the trail and the hose in the driveway.
    Hope this helps
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have the 6A also.. I have had it sbmerged and it has been pressure washed and has never failed. Plus it is usually coverd in mud!
    [​IMG]GO PENS!!!!!!!!!!
  4. johnny reb
    Mar 6, 2000
    326
    Pittsburgh, PA
    Was it relatively simple to install?
    I'm also a huge Pens fan, but it looks like their season is going to end very soon.
    1986 K5, New GM 350, Edelbrock Intake, K&N Air Filter, Flowtech Headers, Dual 3" Exhaust, 33" Pirelli Scorpion AT, 700R4, 3.42 gears
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Yes, it is relatively simple.... The directions are very good and I think the newer models have nicer connectors. I had to attach my own connectors onto my 6a, but it is somewhat old.
  6. K10
    K10 Registered Member
    Feb 18, 2001
    52
    Rexburg, Idaho
    I would get the 6AL for a few dollars more. It has a built in rev limiter.
    <A target="_blank" HREF=http://nick.rockcrawler.com>http://nick.rockcrawler.com</A>
  7. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    MSD ROCKS! I have loved the msd Ignitions since they first came out. I am running a 6al in my truck. I love the rev limeter. I can't seem to lift my foot when I need to so it's a big plus!! If I didn't already have this box, I would get the off road box. I just got mine back from MSD agian for repairs. I keep blowing an internal fuse link. They said is was from blunt force trauma!! (hard landings.) I will most likely replace it with an off road one as soon as funds are available. They are easy to install.
    your right. I don't understand the jeep thing!
  8. dyeager535
    26,975
    Waste of money if you are looking for power. Get some better gears,headers, or a bigger motor, then worry about spinning your motor above the stock HEI's limits.
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
