MSD Ignition bypass ?'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hossbaby50, Jan 7, 2002.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    MSD Ignition bypass ?\'s
    I have a 4 pin module and I am having ignition problems. I need to know how to bypass my MSD 6 box to rule that out. I have the module and wiring removed to put the MSD in, how do I hook up the module and get it to run on the distributor like normal? thanks
    Harley
    My Chevy isn't broken, its just out of gas.
  2. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    Re: MSD Ignition bypass ?\'s
    What year truck and what engine? also are there 1 or 2 wires goin into top of factory coil?
    Neil H. Alabama.. "It's a full size thang, Jeep owners don't understand!!" '78 K5 400ci 4x4 AT,AC,PW Cheyenne., '74 C10 4x2
  3. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Re install the module and plug the connector back into the distributor cap also plug the battery connection back into the cap, it is that easy
