MSD ignition worth it??
Discussion in 'The Garage' started by down4thakrown, May 15, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    If u got it, how do u like it? Whats the differance from HEI??
  2. Boondocks
    Boondocks 1/2 ton status
    May 10, 2005
    129
    Massachusetts
    I installed the MSD Pro-Billet distributor, Blaster 2 coil, 8.5mm Superconductor wires and the 6AL multi-spark in my 72 K5 with GMPP 383HT.
    Also, the 6AL has a rev-limiting feature, but the rev adjusters it came with skip from 3000 to 6000. My motor reds at 5000.
    Also, the distributor comes with different curve spring sets.
    I noticed better low-end torque and it now starts almost immediately after the starter engages.
    I was very pleased with the twin 10 foot burnout on my 16.5 by 10's too!
    It works great and looks good.
  3. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    my old motor was oil burnning monster. put msd stuff on like above and whent 5-6k miles more on a set of plugs. if that helps you.
  4. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    I run an MSD Digital/Programable 7 with a Crank Trigger. They make excellant products and have excellant tech Support
  5. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    how much did that setup cost ya?? so if i put an msd on my truck will i still have to set the timing with a timing light or does the box take care of that???
  6. Boondocks
    May 10, 2005
    129
    Massachusetts
    I don't remember what I spent. You could price it out online at Jeg's
    Yes, I still had to time it and I used a light to do it. The 6AL box only provides the multiple spark and rev-limiter.
    They do make a newer distributor the does electronic advance, but mine has a vacuum advance.
  7. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I have a mallory billit HEI, and it works great, truck starts right up every time, I just wish I had a rev limiter.
  8. sweetk30
    Nov 1, 2004
    25,552
    546
