MSD Ignition
Discussion in 'The Garage' started by ramses, Oct 27, 2005.
  1. ramses
    ramses 1/2 ton status
    Jul 2, 2004
    238
    West Virginia
    Is there a way to test if the MSD ignition in my truck is working right? The reason I ask is because I thought that if the power wire coming from the battery to the MSD box wasnt hooked up it wouldnt work and the motor wouldnt run but I had the wire unhooked yesturday for a minute and it didnt quit or anything. Is there any way to really test to see if its working right? Honestly I never noticed much difference after I installed it which makes me wonder why I spend $200 on it lol.
  2. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Might try the MSD web site. I think it's www.msdignition.com I think they have a pretty good tech section.
  3. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
  4. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    What dis. do you have? I know with mine i run the msd direct plug in dist. and it will not run if that wire is not hooked up. You should notice a smoother idle and better pickup. what did you gap your plugs at? Should be around .050 or so depending on compression of the motor.
