MSD Ignition
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Smitty, Nov 13, 2000.
  1. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Installed an MSD 6A on my 82 yesterday. I'm amazed at the difference in the way the engine starts and runs. It cranks up a lot easier, even on the cold mornings.
    Has anyone else installed one of these and if so, did you expand the plug gap after the installation?
    Smitty
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have the complete MSD set-up. I haven't increased the gap, but I was thinking about doing so. I was thinking of going up to .55 or .055 what ever the hell that is.
    Where you thinking of going for a larger gap? IF so what size where you thinking of going up to?
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. mich89k5
    mich89k5 Registered Member
    Oct 30, 2000
    40
    Michigan
    I'm planning on getting one too within a week, but I was wondering if the Offroad box is better all around or is it just more of a waterproof/vibration resistant version of the 6A. Have you heard anything on the difference. Where did you get yours and how much? Also was mounting it a problem and where did you end up mounting it?
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I am running MSD8360 dist with 6Abox and BlasterII coil. My gap is set to 45 and timming is 8!
    I love it!!
    OFF-Road version will run UNDER water the 6A may for a minute or two but not for ever! From what I remember that is the only diff, oh ya it also comes with the rubber mounts like the 6T does, but that is it.
    I would email MSD to find out for sure, they are very helpful!! Good Luck
    http://www.burt4x4.coloradok5.com
  5. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    The paperwork that came with the box says to start opening the gap .005 at a time and to keep an eye on plug condition. I've got them set at .045 (my factory setting) right now but will start opening the gap. Picked mine up from Summit for $132. It was at my door 2 days after I ordered it. The installation was straight forward and I ended up putting the box on the firewall. The whole thing only took about 45 minutes to put in once I figured out that the system eliminated the factory ignition control module (instructions are a wonderful thing).
    I really bought the thing for my Ford but was messing with the Blazer and it just ended up under the hood. Figured I'd try it out to see if I'd want to invest the extra money in the off-road version. Guess I'll make another order in a couple of weeks then I'll put this one on the Ford since it doesn't get off the hard stuff.
    Smitty
  6. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    I just got the Offroad box, distribitor, coil and 8.5 msd wires...i havent installed it all yet...my motor hasent showed up so i am kinda stuck...but ill let ya know how it comes out
    "whoo my new pic is on the photo page...check it out!!"
  7. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    It eliminates the ignition module? That means you have to open up the distibutor and start taking stuff out? Sounds scary.
    -- Mike
  8. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    <font color=blue>Piece of cake, the MSD comes with the wires that plug into where the ignition module used to be, and it has the nylon (plastic, whatever) hold-downs to keep the wires from hitting the bottom of the rotor. Steve</font color=blue>
    <font color=blue>Steve Sosa a.k.a. "sosaman"</font color=blue>
    http://sosaman.home.texas.net/carpics.html
  9. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I used to have one but it shorted out and got fried. I am thinking about gettign another one but was wondering how straightforwrd the wiring is? I really hate wiring things. I bought my truck with the last one, so I don't know how hard it is.
    90K5
  10. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    The wiring is simple. If you go to www.msdignition.com you can check out their schematics. I've been told that their tech reps are super helpful if you run into a snag.
    Smitty
  11. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    Is there a big difference between GM HEI and aftermarket MSD? I was under the immpression that the GM HEI was already pretty darn good.
  12. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    I think the GM HEI is one of the best factory ignition systems made. The MSD unit just makes it better.
    Smitty
  13. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    the GM ignition is great, it just loses some oopmf in the upper rpm range. the MSD solves that, adds better throttle response, mileage and starting.
    Knife.
    knife.coloradok5.com
  14. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have had my 6A under water, covered in water-mud-etc... It keeps on ticking!!!!!!!!!
    Mike [​IMG]
