MSD pro billet distributor...Opinions?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shawnboy, Dec 23, 2005.
  1. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Anybody running or has run the MSD distributor in their tbi rigs? Wouldn't mind your opinions. I'm running the stock set up on a 350 crate engine and I think an upgrade is due.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Dont waste your money. MSD Dist is no better than stock TBI unit. Unless yours is worn out dont replace it. If you want an ignition upgrade an aftermarket Coil and some good wires, cap,& rotor is all you need. Personally I am not a big fan of MSD.
    These:http://www.performancedistributors.com/gmcomputerdist.htm are better IMHO and cost less. Also their dist modules, coils and wires are very good.
  3. J.R.
    J.R. Guest
    i use MSD in all my toys and they always perform great.. if you have a bone stock engine then a factory replacement will serve you well. but if you are going to add performance mods to it then ungrade to MSD. a MSD ignition box(6,6A,6T) added to your HEI unit now would be a better investment in my opinion.
  4. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I used to have a Mallory in my '73 before it was disassembled. Never had a problem with it. But I never had any troubles with the HEI setup either. Always worked great for me.
  5. mrk5
    Apr 20, 2004
    12,351
    1,050
    Northern Colorado
    I don't have TBI, but I am running an MSD Pro Billet distributor.
    I needed a new distributor, so I went with the MSD unit. Primarily because I like the smaller cap.
    Haven't had any issues with it. I don't think it is any better than the HEI, though. I know when I priced an HEI distributor through Carquest, it was about the same price as the MSD.
  6. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I agree. I used an MSD setup in a drag car many years ago, and it didn't do any better than a stock HEI. It may be more reliable at higher rpms, but my experience doesn't show that its worth the extra $$$.
    Its just under hood bling!
  7. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Like mrk5 I bought one when I needed a new distributor. IMPO there was a difference but not enough to justify the cost. If they'd frop the price it would be worth it to just go out and buy one, but I wouldn't recommend it. Save a few hundred dollars for a disc brake swap or a frame brace.
  8. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    I use one and also msd boxes as well, I think they make a great product... but, like thunder says, as far as the dist. goes unless yours is broken leave it alone, Gm makes a good dist.
  9. shawnboy
    Jun 22, 2001
    468
    I needed a frame brace last week so this week I'll get a new distributor. The stock one has been in 3 engines and has 400,000 k's on it. That and the module is acting up and rather than swap out modules I thought I'd treat the LT1 to a new dist. Next on the list is high steer. Thanks for all the input on the original thread, lads.
