MSd question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TXsizeK5, May 9, 2002.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    How much does it run to buy everything: box, dist, coil, plugs, wire + install at a reputable shop?
    Is it also bad to run the box itself or everything MSD but OEM distributor? Thanks.
  2. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Look at www.summit.com at there msd-6 series boxes,then go from there with the wires and plugs ,coil, and why go to a shop You can do it in about 1 hour for all but the dist....It is very easy...mike
  3. high&liftedup
    high&liftedup Registered Member
    Nov 14, 2001
    64
    CA
    If you buy the HEI Distributor, the MSD box is very easy to install... They give you ok directions (it helps if you know a little bit about dc theory). The MSD reps are excellent.
    Just a quick est:
    off road box=$215.00
    HEI Dist.=$320.00 (comes complete w/coil,cap,rotor)
    Superconductor Wires:$60.00
    ... as far as running the MSD box w/stock distrib..... No problem...
  4. sinchphoto
    sinchphoto 1/2 ton status
    Mar 7, 2000
    366
    Southern California
    i paid like 425-500 for everything and self install is really simple.
    got it at paw. performance automotive warehouse
