msd vs. dui
Discussion in 'The Garage' started by nicotine, Jan 27, 2004.
  1. nicotine
    nicotine 1/2 ton status
    Jan 11, 2004
    116
    wich is better an MSD setup or a DUI i really like the setup of how it is all in one with the DUI. so wich is better. and does anybody run the DUI and with what results?
    /forums/images/graemlins/thinking.gif
  2. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    I'm sure at least one person on here has "run" so they wouldn't get a DUI -I'm sure the results were spectacular /forums/images/graemlins/deal.gif
  3. nicotine
    Jan 11, 2004
    116
    well one way to be a samrtass /forums/images/graemlins/rotfl.gif, but my question were about destributers. /forums/images/graemlins/thumb.gif
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Well getting a MSD would make my day...and getting a DUI would suck for a long time with all the court costs, jail/bail, higher insurance...
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    Back on topic:
    DUI is just a kit so you can bolt a GM HEI dist. into other makes of motors. It is still mostly just a stock HEI. I didn't know they made one for a chevy (there wouldn't be much to make as you already have one on your motor /forums/images/graemlins/confused.gif). I bet it is just a GM HEI dist with some slightly better parts that you most likely wouldn't notice.
    As for the MSD I have never used one but have heard very good things about them. Installing a MSD would produce actual noticable differences esp. at low RPM lugging the motor.
  5. nicotine
    Jan 11, 2004
    116
    what does a complete msd kit cost excludeing wires?
  6. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
  7. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    I have the DUI unit on my small block ford, and had the MSD on my k-5. I took the MSD off my k-5 because it caused problems with my ECM, I kept getting code 42's.
    I like the DUI better. It is just like the standard HEI, but with performance parts. The ignition module has more dwell built into it, and the coild is rated to run at a much higher RPM. Plus if something ever goes wrong with it, all you have to do is replace it with a standard HEI part.
    That being said, I did notice a smoother idle and startup on my K-5 with the MSD unit. But once again, I know a lot of people that have had troubles with MSD units - not everyone, many have had no problems with MSD units, even years after the initial install.
    I went back to stock HEI after having my "code 42" gremlin. Now it's gone. I believe the MSD caused some interference issues. I think the DUI might have done the same thing though.
    Anyways, to sum things up, I always say, the simpler the better. The DUI is just like the stock HEI, AND when you buy it you get a brand new distributor with all new parts, versus using some of the old parts with an MSD. For older trucks, that use vacuum advance, the DUI can be recurved for your motor...
    Oh yeah, no problems after 1.5 years with my DUI unit on the Ford...
    my .02 /forums/images/graemlins/peace.gif
  8. nicotine
    Jan 11, 2004
    116
    is there msd distributors that are better than stock that you can use with that kit?
  9. nicotine
    Jan 11, 2004
    116
    or does that kit just go with the stock chevy distributor?
    does it really improve performace that much?
  10. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    It depends. do you have emmissions to worry about? MSD only makes distributors with the 4 pin ignition module. If you have the 5 pin or 7 pin, there are no direct replacement MSD units. You would have to go with a 4 pin replacement unit, and hopefully you don't have CA or Fed emissions...
  11. nicotine
    Jan 11, 2004
    116
    no emissions, so is it better to get a upgrade distributor or to keep the stock chevy on and run the msd kit?
  12. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
  13. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    I have had both /forums/images/graemlins/grin.gif First I ran a stock dist. with a 6A box and coil. Then I added the the Pro billet dist. It was very nice. But my problem was the 4 and 5and 6 pin thing. I put a fuel injection kit on and the MSD set up could not be advanced or retarded. I needed the DUI style dist. that could be advanced or retarded by my computer. The Dui is very nice and very simple. It is far from a stock unit. But Like mentioned above if something failed you can replace the parts with stock equipment or give performance dist. a call and get replacements. /forums/images/graemlins/grin.gif
    My dist is set at 11 degrees and then the computer can alter it when necessary /forums/images/graemlins/laugh.gif
  14. nicotine
    Jan 11, 2004
    116
  15. nicotine
    Jan 11, 2004
    116
    also with the dui do you have to run the LIVE WIRE spark plug wire?
  16. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    It does not look to me like the racing version is cheaper....I would go with the street/strip version. The only real way to tell which one is best for your application is to give them a phone call or E-Mail and talk with the guys that actually built it.
  17. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    I really don't think you need a distributor capable of spark at 9000rpm.....unless you have a really awesome small block chevy.... Plus the race version is 60dollars more. I would give them a call and see what theyrecommend. They are very helpful there...
  18. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have used both MSD and DUI (performance distributor) Parts.
    I like DUI the best. They are simple and work good.
    I really like their distributors and coils.
  19. nicotine
    Jan 11, 2004
    116
    are the live wires required or can all spark plug wires work?
  20. nicotine
    Jan 11, 2004
    116
    called them they told me live wires are good but a godd set of taylors will work and that is what i have /forums/images/graemlins/peace.gif. by the sounds of things must people here are really pleased with the dui, how much did it do for performance numbers? /forums/images/graemlins/thinking.gif
