  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    What does the MSD box and coil replace? Is there a stock box and coil? Is it an easy "swap"?
    6in 87' K5 w/ 35" BFG muds.
    Kn filter
    Man, I need 350
    Damned 305's.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The coil is an easy swap. Your currnet coil should be on the distributor cap. I did it myself back when I was a total novice at wrenching. The instructions that come with the coil are very good. The new coil goes right in were your old one came out of with no mods. I didn't do my box though. The wiring diagrams are very good, but I didn'twant to chance it so I had my mechanic do it. If you are familiar with electrical wiring on your truck you could do it pretty easy I think. The box make a world of differnece over stock, but the wires and coil help too.
    If you get the box first get everything at the same time. The box amplifies the voltage going to the ignition and will burn out the stock coil quickly. The MSD coil puts out more voltage than stock too. I would recommend MSD super conductor 8.5mm wires that way the most voltage possible get to the spark plug. I run a spark plug gap of .057 compared to the stock .035 with my MSD setup. The extra gap gives you a more complete combustion which equals power. I run the MSD 6 Offroad box, MSD HEI coil, and MSD 8.5 SC wires.
    My MSD probably has paid for itself in gas savings already. Not to mention the huge boost in drivability and throttle response.
  3. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I run a MSD 6A box myself...well on my old truck i have yet to nstall it on my blazer but thats coming soon....I love it!
    What? You think the hole is too deep? Lemme see...
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I currently have a MSD 6aOffroad ignition and it rocks. Personally I would get the coil and upgrade to some MSD or Taylor wires... gap the plugs at .060 and you should see a great gain for little money. The HEI system really is fine for our trucks.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  5. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Hey Mikey. I'm getting ready to add the 6A box, coil, Accel cap and rotor, MSD wires to my truck. Will the .60 spark plug gap still work for me...since I have the Vortec heads??
    '73 K5
    Chevy good...Ford bad
  6. Philly87
    Philly87 1/2 ton status
    Jul 14, 2000
    465
    6
    El Paso, TX
    Hossbaby50 is right about everything but one thing. Because your truck is an 87 it will have an external GM dual connector coil. MSD offers a direct replacement coil for this application. The part number is 8226 or called a Blaster GM. If you're worried about wiring, MSD also offers a direct plug in harness for your truck. The harness is part number 8876 if you are using a 6A or 6AL box. If you are using the 6470 Offroad Ignition the direct plug in harness will be part number 64602. With these harnesses no cutting or splicing will be needed. It will actually take you longer to mount the box than it will to wire it up. You can even go as far as replacing your distributor with a part number 8366 Pro Billet Distributor but that's really not necessary. If it aint broke don't fix it. :) Hope this helps. If you need anything else feel free to ask or you can e-mail me at pchacon@msdignition.com.
    Good Luck,
    Philip
    MSD Tech
    P.S. I personally run the Offroad Ignition, 64602 harness, and Blaster GM Coil in my 87 Blazer as well and love it all.
  7. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    Yup when you changed to vortecs you should't of opened up the plug gap any because that has more to do w/ ignition power, but if you go MSD .060 has given me the best results.
    Also anyone using MSD may want to go to either a MSD module or get the kit to bypass it. I haven't installed my module yet and everything has been fine w/ the MSD thus far though.
    -Mikey
  8. loudandproud
    loudandproud 1/2 ton status
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    CaptCrunch, which spark plugs are you using? I am thinking of getting the msd 8.5 wires, the msd offroad ignition and the msd blaster gm coil.
    Thank you
    <font color=blue>'90 Jimmy</font color=blue>
    Web page - http://coloradok5.com/gallery/album08
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I run Champion Truck Plugs. They are gapped to .057, and they are a stage hotter too. PN4018 if I remember correctly.
    <P ID="edit"><FONT class="small">Edited by Hossbaby50 on 10/05/01 05:41 PM.</FONT></P>
  10. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I'll answer that for him (because I know what he likes to run... LOL) NGK's! (or A/C Delco's)
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  11. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    How much did you guy pay for your MSD 6 Offroad box AND coil? Where's the best place?
    Are the 8.5mm wires neccessary? I have brand new 8mm wires and they have a lifetime warrantee. I'm kind of cheap that way since wires are supposed to wear out.
    The box, new coil, 8mm wires, and some platinum plugs at .060 or so. Sound good?
    -- Mike
    <font color=blue> The mud's on it to hide that it's more than one color.[​IMG]
  12. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    I just got some MSD helicoil wires that you cut to lenght and crimp the end on. these are 8mm wires, and even come with a crimping tool (you need a vice to use it). the wires were awesome.
    I tell ya what this was a really good investment, and they wires are great for use with after market inginition systems.
    it is so nice to have your wires the exact length you need without excess you gotta worry about!
  13. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The best place to get the MSD parts form Checker Auto parts. They will match the prices of Jegs or Summit, and you don't have to pay shipping. Jegs and Summit are the next best place to get them. The box Offroad 6 box is about $215, the coil is about $75, and the wires are between $58-80. They make precut wires for some Chevy trucks ($58), but they are a little short. I would get the cut to fit wires that why you can route them any way you want.($80)
    I ran non MSD 8mm wires with the box and coil. When I put the MSD wires on you notice a difference. If you don't use the MSD Super Conductor wires you will not get the full potential of your box and coil. You don't have to get them when you get the box, but you should probably get them some time.
  14. loudandproud
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    Do I have to buy the rev limiter for the offroad box right away for it to work, or can I buy it later on down the road?
  15. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The Offroad rev limiter is optional. The box will work with or without the limiter.
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Why can't you just use the 6AL box in your trucks? Do you really think that the off road box is all that more durable that it's worth it? If I remember right, the 6AL box is cheaper than the off road box, and it comes with a rev limiter.
    If I upgraded to aftermarket ignition, I think that I wouldn't expect a whole lot of benefit. I might consider doing it one day anyway though--the rev limiter alone would be worth it.
    Tim
  17. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The offroad box is waterproof and vibration proof. That is worth the extra cash. The rev limiter is nice, but not that necessary to me. I don't run 5000 RPM in mud. I offroad at slow speed. The connections of the offroad box are waterproof too. There is a 99.9% chance that you will never short out the 6A box, but better safe then sorry.
    You would be surprised how much a Hi performance ignition can benefit your truck. My MPG went up, my power went up, and the biggest benefit is driveability. It is an upgrade I would recommend for anyone.
  18. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    I currently switch back and forth between NGK V-Powers and AC Delcos... each is gapped @ .060
    -Mikey
  19. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    I'm planing on putting on my 6A this weekend and I was wondering If I take out the modual?
    KEN
    DANGIT it's not a bronco!
  20. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    The 6A looks like a good choice
