MUD BOG BOOGIE
Discussion in 'Mid-Atlantic Region' started by slimlynn1, Aug 4, 2003.
  1. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    The East Swanzey Fire and Rescue is sponsoring a mud bog August 24th in East Swanzey, NH. It is at the Cheshire fair grounds Rt. 12 in East Swanzey. Racing starts at 10:00. Come on out it is a great time. For information and rules call 603-352-0698
  2. angrysnowplow
    angrysnowplow 1/2 ton status
    Jan 8, 2002
    502
    MA
    Aww, I was gonna post about this. /forums/images/graemlins/grin.gif
    Think I'll enter if my axles are in by then. /forums/images/graemlins/thumb.gif
  3. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Hmmm... sounds interesting! Maybe I'll have to go to this since I've already gone to the hill climbs and the jamboree /forums/images/graemlins/thumb.gif
  4. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    Oh and Mark, I'll help you install your axles if you help me install mine /forums/images/graemlins/grin.gif I'm gonna make a post in the forum to see if anyone else wants to give me an extra hand/ tools. Let me know if you're interested. /forums/images/graemlins/thumb.gif
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    NoAngel and I will probably make an appearance.
  6. 77 Mud Buddy
    77 Mud Buddy 1/2 ton status
    Oct 31, 2002
    228
    Austin, TX
    I'll be there with my friend Jeff AKA "Beards88". I am assuming your heading up the day of the event Aug 24th. If so we can caravan / carpool.
  7. angrysnowplow
    Jan 8, 2002
    502
    MA
    I called and they e-mailed me the rules:
    East Swanzey Fire and Rescue Company
    Mud Bog Boogie
    GENERAL RULES
    1. Seat belts are required in all classes. Shoulder harness are reccomended in all classes.
    2. A minimum 2 1/2lb. Dry chemical ABC fire extinguisher (with gauge) in easy access is required.
    3. All open and soft-tops must have a roll bar.
    4. Front and rear loops attached to frame for tow out of pit mandatory. (3" minimum inside diameter).
    5. Driver must be at least 16 years of age with parent or guardian approval – signed by parent and witnessed by a Mud Bog official the day of the event.
    6. Driver must have a valid driver’s license to be shown at the time of registration. No License-No Participation-No Exceptions-No Excuses.
    7. No riders in any vehicle while in competition.
    8. No loose objects in race vehicle.
    9. SNELL or DOT approved helmet required in all classes. Neck collar recommended.
    10. Fire retardant suits, including gloves, are highly recommended for all classes.
    11. Battery must be securely fastened and is not allowed in the driver’s compartment.
    12. Vehicle may not be left unattended anytime the engine is running.
    13. Classes 1 & 2 limited to Stock automotive engines only. Only one engine per vehicle.
    14. Fuel tank-cell recommended. All tanks must have positive locking or screw caps. Aluminum tanks okay. Must be located inside frame perimeter and securely fastened. Street classes – factory location or under floor of bed.
    15. Vehicle must have forward and reverse gears and must be 4-wheel drive.
    16. Brakes: hydraulic brakes required – driveline brakes ok. Must be able to skid tires and positive lock dual master cylinder recommended.
    17. Competition vehicles must be operated in a safe manner at all times, in the pit area, staging, loading and unloading, and on the track itself. Officials have the right to stop and/or disqualify any vehicle not being operated in this manner. Entry fees will not be refunded.
    18. No alcoholic beverages are allowed on Fair Ground Property. No driver will consume alcoholic beverages or take drugs prior to or during an event. Obvious consumption of alcoholic beverages by pit crew will be grounds for disqualification of the driver and race vehicle. Any infractions of fighting, drugs, alcohol, theft, unsportsman-like conduct, tampering with a competitors racer can result in (depending on the severity) suspension up to five years and/or fines up to $5,000.00.
    19. Any competition exhaust allowed. It must exit either straight up or straight back.
    20. Stuck or broken vehicles will be measured to the center of the front hub for distance. Drivers will place the vehicle in neutral or park, remove and raise hands from steering wheel while being hooked up for removal from the pit. Vehicle must remain in neutral while being pulled.
    21. Course boundaries are marked with stakes or markers. Anyone passing or hitting these will be out of bounds. Vehicle will be disqualified. This will be at the officials’ discretion.
    22. Set back rule: Driver is allowed 3 minutes to get to start line. If you are unable to make it, you can have the next driver go ahead of you and then go. This is at the discretion of officials.
    23. You break it, you buy it. This includes the timing lights.
    24. Vehicle may enter maximum of two (2) times per class
    25. Vehicle may only place once per class.
    26. All decisions by race officials are final.
    Winners of Class 1, 2, and 3 will receive a trophy PLUS
    · $300.00 first Place
    · $200.00 second place
    · $100.00 third place
    Winner of Class 4 will receive a trophy PLUS
    · $400.00 first place
    · $300.00 second place
    · $200.00 third Place
    Mud Bog Rules and Regulations for classes
    Class One (8 cyl. Street legal):
    1. Street legal engine swaps allowed.
    2. No aluminum engine blocks
    3. Single carb or factory injection only.
    4. Pump fuel only. No alcohol.
    5. No nitrous oxide or blowers.
    6. Stock wheelbase only.
    7. Must have full factory body.
    8. Must have full factory dash. After-market gauges okay.
    9. No cutting on body or firewall except trimming fenders to clear larger tires.
    10. Must use factory suspensions. Lift kits okay.
    11. No gutting drivers compartment or doors.
    12. DOT uncut tires only – any size.
    13. Must use factory transfer case.
    14. Must follow all general rules.
    Class Two (4 & 6 cyl. street legal):
    1. Single carb or factory injection only.
    2. Pump fuel only. No alcohol.
    3. No nitrous oxide or blowers.
    4. Stock wheelbase only.
    5. Must have full factory body.
    6. Must have full factory dash. After-market gauges okay.
    7. No cutting on body or firewall except trimming fenders to clear larger tires.
    8. Must use factory suspensions. Lift kits okay.
    9. No gutting drivers compartment or doors.
    10. DOT uncut tires only – any size.
    11. Must use factory transfer case.
    12. Must follow all general rules.
    Class Three - Pro Stock:
    1. Must have stock appearing frame
    2. Must have stock appearing body silhouette.
    3. Must use stock type suspensions at front or rear, other may be modified. Maximum 2 coilover shocks.
    4. DOT unaltered tires – any size.
    5. Must be carburetor or OEM fuel injection. No aftermarket fuel injection.
    6. No nitrous or blowers.
    7. Pump fuel only. No alcohol.
    8. Must follow all general rules.
    Class 4 – Open class
    1. Anything goes.
    Looks like I'm out, I doubt 4Wheel Parts is gonna get my rollbar here in time. /forums/images/graemlins/mad.gif
  8. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    Put your hard top back on and you're all set if I'm not mistaken /forums/images/graemlins/thinking.gif
  9. slimlynn1
    Apr 9, 2003
    336
    Hamden, CT
    Your half top should be fine.
  10. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    I wish I could go but the 24th is my wifes due date. /forums/images/graemlins/frown.gif
  11. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    Is everyone still going to this? I'm trying to figure out what I should do on the 24th still /forums/images/graemlins/rolleyes.gif
  12. 77 Mud Buddy
    Oct 31, 2002
    228
    Austin, TX
    as posted in "Lyndonville Mud Bog August 23rd", my fiend Jeff and I are going to both of these events, and possibly stay with Andrew / slymlynn or get a hotel room. Your welcome to ride with us or caravan if you think you might need your wheels!
  13. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    I get to go, WOOHOO Baby was born Aug 14. Very happy.
  14. slimlynn1
    Apr 9, 2003
    336
    Hamden, CT
    Trucks all loaded ready to go. Got the new 37" Boggers and ready for the mud. See you up there if your going.
  15. Leadfoot
    Nov 28, 2000
    3,112
    1st Congrats on the baby /forums/images/graemlins/thumb.gif
    2nd Unfortunately due to the Nachi computer virus I will not be able to go /forums/images/graemlins/frown.gif. I had to pull a couple 16-20 hours shifts to get the hospital network back up and running and fell behind on my side business (lawns) and will not be able to make it. Hope you do well and everyone has fun....maybe next time.
  16. slimlynn1
    Apr 9, 2003
    336
    Hamden, CT
    MA87K5 Congrats on the new baby, Hope to see you at the BOG.
  17. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Will there be a meeting time and place for everyone to meet?
  18. slimlynn1
    Apr 9, 2003
    336
    Hamden, CT
    We will be at the mud bog at about 8:00 Am. Look for us in the pits. My Blazer is Black and grey with a CK5.com sticker on the window. We are up in Vermont now and are going to the Lyndonville mud bog on saturday. If you want to come and hang out with us on sat night call us in VT. 802-228-4387. or call Prescott on his cell phone 512-658-1255. We should be back at the house by 8-9 pm. Pm me or respond. I will check later tonight and tomarrow. Later
  19. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Can't make it sat night. But I be there for 9am if I don't get lost on the way up. First time and all. See you there hopefully.
  20. slimlynn1
    Apr 9, 2003
    336
    Hamden, CT
    Well we will be there but not untill about 10:00. I will not be racing though. Some minor breakage in Lyndonville, front and rear drive shafts snapped. See you there. We will be parking in the competitors parking lot, you can find us there.
