Mud Bog need help
Discussion in 'The Garage' started by JohnDeere, Mar 5, 2007.
  1. JohnDeere
    JohnDeere 1/2 ton status
    Jan 17, 2006
    342
    Houston, Texas
    Im planning on entering some mud bogs this summer and need some help.
    I want to stay in the stock class so I'm going to run 33. I'm planing on running 33/13.5/15 LTB. What I need help on is do I run in hi or low range. I have a 350tbi/7004/208/4.10? If I ran in high I would put in in second gear right and if in low then I would run in drive.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i never understood the mentalality of running in low range in the mud, wheel speed is your friend.
  3. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Wheelspeed is your friend, yes...but I have run into mud where my 305 was barely able to spin the 33's in low range... so definately depends on the consistency.
  4. UPS
    UPS 1/2 ton status
    Aug 2, 2006
    438
    Maine
    I have been in sandy mud that was 4' deep but thick, where my 305 would only turn 4000 RPM in low range first gear in the 700R4. The truck has 3.08 gears and 35" Boggers so that doesn't help at all.
    It all depends on the mud.
    Mike
  5. 85mudbogger
    85mudbogger 1/2 ton status
    Feb 5, 2007
    226
    missouri
    imo i would try high if it was a mud drag with like 10 inches of mud but you said bog so im guess its as far as you can go type of deal so i would do the low range and put it in drive, i doubt if it will shift out of second anyways unless the start is very soupy and shallow, put it to the floor and let it eat and if you do hit drive(doubt it) it will probly go right back to second, dont think high range would be the way to, i have never seen even the skimmers that run t cases instead of chain drives opt for high range unless its a manual, automatics and high range is usless for going fast unless u have 6.72s and 33s lol
  6. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    :thinking: :thinking: Can you say no traction on street?:D
  7. JohnDeere
    Jan 17, 2006
    342
    Houston, Texas
    Thats what I was kind of thinking. Unless I had a built motor that would really spin the tires then I would have to run in low. thanks
  8. JohnDeere
    Jan 17, 2006
    342
    Houston, Texas
    Oh wut tire pressure should I run. Would it be better to run normal tire pressure for more floatation or to have about 10psi in it for more traction
  9. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,548
    16
    Anchorage, AK
    Lower pressure gives more floatation.
  10. JohnDeere
    Jan 17, 2006
    342
    Houston, Texas
    how does that work. is it becase the tire flatens out more and has a wider print so it will want to stay on top more?
  11. AKbigsub
    Sep 9, 2005
    1,548
    16
    Anchorage, AK
    Basically!
    We all air down up here when we drive in boggs (tundra, peat, etc.) and it also works great in sand and snow.
  12. JohnDeere
    Jan 17, 2006
    342
    Houston, Texas
    ok thanks for all of yall's help
  13. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,614
    71
    Living in a dump, VA
    i ran mud bog for 2 years here in va...heres what ic an tell ya...if you dont have the a huge motor you want all the gear you can get...i ran 513s and a 208 (2.8 to 1 i think)it still was not enogh gear....you want all the gear you can get so you can pull high gear (like second and 3rd)in your truck...as far a pressure goes i never really meesed with that...my sucuess in mud bog never came with wide tires...i ran a 38x11 bogger which is now only allowed to be run in xx clas with tractor tires at the place i ran...thats why i got out couldnt compete...tall and skinny dig in mud...fat wide tires float...but i will attest to this...tall and skinny if you hook up in the mud is sure to break a 44...i never did but seen it happed many times...just my .02
  14. LVJimmy
    LVJimmy 1/2 ton status
    Aug 22, 2005
    301
    Lost Wages, NV
    low range, brake torque, 15 to 20 psi.
  15. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Depends on the mud. If it has no bottom or your tires can't get to the bottom low pressure. If your tires can get to the bottom high pressure so they will sink to the bottom faster
  16. LVJimmy
    Aug 22, 2005
    301
    Lost Wages, NV
    with 33" tires I hope he isn't going to reach the bottom. If he does it won't be much of a mud bog.
  17. 85mudbogger
    Feb 5, 2007
    226
    missouri
    yeah run about 15 to 20 psi low side in drive, let it eat, those ltbs are bias if i am correct so runin 15 psi is like runin 50 psi in a radial, its not gonna float its gonna go to the bottom anyways if it can reach
