Mud flap Ideas??
Discussion in 'The Garage' started by smprider112, Aug 10, 2004.
  1. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    Ok heres my dilema...I need some type of mudflap (obviously /forums/images/graemlins/rotfl.gif) to make this truck street legal....so now I need ideas on how to build some type of mudflap and bracket to attach it with...possibly even removable, that doesnt look dumb (kinda hard with a truck like this /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif)
    Im thinking using some type of angle Iron either welded or maybe bolted to the frame?? and please dont even think of saying just drape it off the exhaust /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif this pic is old, and so are those pipes! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    drape itover the exhasut! /forums/images/graemlins/ignore.gif
    You could get a piece of sqaure tube and bolt it to the frame, then extend it .5" past the edge of the tire, then bolt some mud flappers on /forums/images/graemlins/waytogo.gif
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Check out the flap brackets and hangers they use on big rig tractors. They have a small hanger that bolts on the frame and the "L" shaped arms go on and easy. Run a hair pin clip to secure them in place. I'll look around here, I think I have a set some where, if I do I'll post a pic tomorrow.
  4. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Go with the rig mud flaps , from your pic it looks to be the easiest
    You can make them look good for the street and easy to remove for off road.
    I have even drilled a 3/8" hole thru the bottom of the flap to hook a bungee cord to hold them up and out of the way so they don't get torn off on pulp trailers in the bush , just sit back and think how you want them to look
    /forums/images/graemlins/thinking.gif
    Or just hang them off the pipes lol /forums/images/graemlins/histerical.gif
  5. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    Get a mudflap of your choice and use a mounting system similar to a receiver hitch, just smaller in size to save on metal costs. You could even use round tube if you were so inclined. A simple pin with cotter pin to hold the mudflap in while on the road and would make for quick removal once at the trail.
    Kris
  6. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    I wish I had kept the exhaust the way it was then...that woulda been an easy setup /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    I'm going hardware hunting today so hopefully I will find something that I can make work....I really like the idea of maybe round tube...weld like maybe a 2" piece of pipe to the frame, then find a round piece that will fit snuggly in it, then drill a hole through the 2 and secure with like a trailer hitch pin or something similar but on a smaller scale /forums/images/graemlins/thumb.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  7. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Easiest way, what some of the others are describing to you. Quick removal too....
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Thats how I did mine, but the bracket flipped upside down!
  9. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    That's what I was talking about. The bracket for the frame end is about 4"s X 1- 1.5"s and uses 2 bolts. Easy and fast way to get flaps that go on and off fast.
  10. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    That sounds like mine. When I'm on the trail I hang them up high off of another set of tubes ware they won't get ripped off or bent up.
    Down Low
    Up High
  11. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Brian, who narrowed your rear?
  12. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    Rob (ugly chevy)
    its his old rig /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/peace.gif
  13. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    ooh I remember now. neat /forums/images/graemlins/peace.gif
  14. 77ChevyK10
    77ChevyK10 1/2 ton status
    Feb 2, 2003
    317
    Laveen, AZ
    i took a pice of angle an welded it to some 2x2 and it slides in the reciver hich.
    Andrew
  15. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    Myfriend tom wheels a narrowed ford, he had the big huge mud flaps, he had a pin set up and removes them for wheeling,
    he stores them under his feet to ack as a heat shield while on the trail, works pretty good, I was dying from the mufflers untill we laid them down /forums/images/graemlins/blush.gif
  16. JDBlazer454
    JDBlazer454 1/2 ton status
    Feb 27, 2002
    951
    Vancouver, Wa
    I am running the big rig mud flap hangers, bought mine at the Mack or Freightliner truck parts place next to Jubitz truckstop next to I-5 near Delta Park, cost me $20 /forums/images/graemlins/thumb.gif You will just have to cut them down a little bit otherwise they are super long.
  17. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Also available at just about any truck stop too /forums/images/graemlins/thumb.gif
