Mud Tires or originals on a CUCV Blazer?
Discussion in '1982-Present GM Diesel' started by airborne808, Mar 9, 2003.
  1. airborne808
    airborne808 Registered Member
    Mar 8, 2003
    9
    Hawaii
    When I bought my M1009 Blazer, the previous owner put mud tires on it. Though the tires are nice and will take me anywhere, I am concerned that maybe it is putting undo stress on the steering box and tie rods. The steering is VERY sloppy.
    Should this be a concern? Should I put original tires back on it? (10R15LT)
    Comments??
    Thanks in advance!
    Jeff
  2. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    You'll be fine. Almost everyone on this forum is runing oversized tires on thier truck. I have 33x10.50 15's on my m1009.
  3. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    First, fill out your profile. Next, you didn't mention what size mud tires.
    I would take a good look at the front linkage for slop (tire rods/drag link/ball joints) then eye ball the steering box mount for cracks on the frame. /forums/images/graemlins/wink.gif
  4. 4xfreak
    4xfreak Registered Member
    Sep 29, 2002
    78
    Bay Area, CA
    Like it has been said before definitely check for cracks in the frame and make sure the tie rods are good. Then dump some cash into a steering brace, either weld on or bolt on. I don't want to plug for anyone but i bought one from ORD and noticed a considerable difference in handling. I also replaced the tie rods which also helped me to run 35's no problem. Heck you might even check the steering gear itself or the pump to see if there is enough pressure going to the gear. If need be look at Redneck rams web page, West Texas Off roads web page and see about modifying your pump to increase the pressure. It just may give you the help you need. /forums/images/graemlins/thumb.gif
  5. airborne808
    Mar 8, 2003
    9
    Hawaii
    Thanks everyone. I'm taking it in for a good once over in a few days. The list is long!
    Jeff
  6. Crunk_K5_1984
    Crunk_K5_1984 Registered Member
    Feb 5, 2003
    87
    Kosciusko, Mississippi
    A steering Stabilizer might do the trick, I picked one up from the local carquest.
